Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk
Old 09-13-2003, 12:09 PM
rmklaw's Avatar
2004 CLK 320 and 2004 Porsche Cayenne
Comand Unit showing NAV active
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9630.jpg
Old 09-13-2003, 12:11 PM
rmklaw's Avatar
NAV INFO IN IC DISPLAY
Here is how the NAV info shows in the IC Display
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9628.jpg
Old 09-13-2003, 12:13 PM
rmklaw's Avatar
TV PICTURE IN COMAND UNIT
Here is the TV active in Comand in motion
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9621.jpg
Old 09-13-2003, 12:14 PM
rmklaw's Avatar
ANOTHER TV PICTURE
Another TV Picture
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9634.jpg
Old 09-13-2003, 12:16 PM
rmklaw's Avatar
TV INFORMATION THROUGH IC DISPLAY
Picture of TV information in IC Display with steering wheel buttons control of TV
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9624.jpg
Old 09-13-2003, 12:17 PM
rmklaw's Avatar
SIRIUS IN GLOVE BOX
This is the Sirius Satellite Radio head installed in glove box
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9611.jpg
Old 09-13-2003, 12:19 PM
rmklaw's Avatar
TV TUNER AND SIRIUS UNIT IN TRUNK
This is how the TV Tuner and Sirius look after installation under trunk deck
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9610.jpg
Old 09-13-2003, 12:21 PM
rmklaw's Avatar
SIRIUS SATELLITE ANTENNA ON REAR HAT SHELF
Note the SIRIUS antenna installed INSIDE on to of hat shelf
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9608.jpg
Old 09-13-2003, 12:24 PM
rmklaw's Avatar
TV ANTENNAS
As you can see the TV antennas are invisible. Four antennas are installed around the rear window hidden under the liner. The GPS antenna is installed under the dash.
Attached Thumbnails Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk-img_9626.jpg
Old 09-13-2003, 01:16 PM
Former Vendor of MBWorld
MBenzNL's Avatar
some slow@$$diesels
I myself would have installed the TV tuner somewhere else (out of sight)...but it works!
greetingz,
Old 09-13-2003, 02:12 PM
rmklaw's Avatar
Installation
Thanks Steve. I had it installed in the trunk so it would be accessible to connect something else to the AV inputs without having to disasemble anything.
Old 09-14-2003, 12:59 AM
MARK335's Avatar
clk 500
tv
i know im dumb, but can the 2003 clk w/navigation also be set up with the tv tuning capabilities. if so, how???
Old 09-14-2003, 01:05 AM
MARK335's Avatar
clk 500
tv
Old 09-14-2003, 11:35 AM
CLK500K3K4's Avatar
2003 CLK 500, 2004 allroad quattro
rmklaw
that's a sweet setup. can all the "after-market" features be displayed on the IC and controlled by the steering wheel buttons? and how much did it take to integrate all that with your clk 320? is the Command system required to having the sirius and tv work?
Old 09-14-2003, 07:57 PM
rmklaw's Avatar
Installation
Sirius does not work through the Comand because it is hooked up through the Aux input. I use the Sirius remote control. Everything else is through the IC and steering wheel.
Old 09-15-2003, 04:37 AM
MBenzNL's Avatar
some slow@$$diesels
All the "OEM" "after market" features can...
mark - one can add a TV tuner to any OEM MB comand system...
greetingz,
Old 09-15-2003, 10:22 AM
FabulusCLK's Avatar
2004 CLK 320
greetingz,
Unless you stick you head in the trunk you cannot see what is there.
Looks just like my CLK. only difference is I have the lighter interior. Looks great!! Can't wait to get mine done. When is steve doing a West Coast trip?
Old 09-15-2003, 03:48 PM
MBenzNL's Avatar
some slow@$$diesels
Steve will be doing a westcoast trip somewhen in november/october.
greetingz,
Old 09-15-2003, 03:57 PM
opusnron's Avatar
2000 SLK, 2003 CLK
If you already have NAV can Steve add the TV tuner and if so do you know the cost?
Old 09-15-2003, 04:23 PM
rmklaw's Avatar
TV Tuner
Opusnron, you should contact Steve. In my case a bought the whole thing from Steve because Steve sells the Comand unit reprogramed to use the TV Tuner and to use it while in motion. I do not think that the US factory units allow for the TV.
Old 09-15-2003, 04:36 PM
FabulusCLK's Avatar
2004 CLK 320
How do we contact steve?
RMKLAW, what was the total price tag for your setup?
Old 09-15-2003, 04:43 PM
rmklaw's Avatar
Steve's Forum name is MbenzNL. Steve MBenzNL s_krabbenborg@hotmail.com. He should be able to give you prices for items you may need. I purchased a number of things from him (great guy) and contracted CarToys for the installation ($550.00 labor). The tuner from Steve goes for $750.00 with cable harness and antenna.
Old 09-15-2003, 07:29 PM
MBenzNL's Avatar
some slow@$$diesels
Yes - but you will have to get your blank TV button activated at your MB dealership...and you should be aware that your dealer cannot get rid of the TV while in motion safety triggers...
The installed TV tuner with all parts needed costs approx 1000USD...when required - I can swap the comand's tunerpart (1 out of 3 comand parts) for one that is reprogrammed to make TV while in motion (for passengers) possible...which will cost a bit extra offcourse.
btw: I will be in the bay area in about 5-6 weeks...
greetingz,
Old 09-15-2003, 11:25 PM
opusnron's Avatar
2000 SLK, 2003 CLK
OK, thanks for the info!
Old 06-11-2004, 11:59 AM
rmklaw's Avatar
Comand - TV - Sirius Install Pictures
Many of you have been asking about install pictures. This is the W209 installation pictures. See begining of thread.
Quick Reply: Pictures Of Comand, Nav, Tv, Sirius Ic Display & Antennas Installed In A 2004 Clk
