265/35/18 tires in the rear ???
Old Apr 3, 2014 | 09:09 AM
Frank Rizzo's Avatar
2024 GLE63s
Anybody know if we can stuff 265's on the rear of a 550?
I know id could use the extra traction!
I can't find the specs on the factory wheels, but I think they are 8.5" front and 9.5" in the rear?? I know the 265 needs at least 9.0" wheel.
opinions welcome.
Old Apr 3, 2014 | 04:58 PM
jkiddd33's Avatar
2005 E55 AMG
I have an 05 clk55 with stocks right now
7.5 and 8.5 dinky rims.. 275 in the rears and its no problem
Old Apr 4, 2014 | 09:22 AM
2024 GLE63s
Thanks ^
Can anyone help with the wheel size or tire fitment?
Old Apr 4, 2014 | 04:25 PM
ambit's Avatar
09 CLK550
Interested in the tire sizes on CLK55 AMG rims as well.
Stock rubber just ain't cutting it!
Old Apr 4, 2014 | 08:09 PM
jkiddd33's Avatar
2005 E55 AMG
What exactly is your question?
265's on the rear of a 550 will be no problem. There are multiple factors in tire fitment: Size, Width, Offset etc.
Be more specific and most likely you will receive more input.
Old Apr 4, 2014 | 09:21 PM
ambit's Avatar
09 CLK550
275/35/18?
What size on the front?
Thanks!
Old Apr 4, 2014 | 10:08 PM
2024 GLE63s
I don't know how to ask it any simpler in my OP.
I asked what size are the factory CLK 550 wheels AND will 265's (or larger) fit in the rear with no issues (like rubbing).
If the factory rears are 8.5" wide then the largest tire that fits is the stock 255. 265's and 275's need a 9" wheel according to all the manufacturer's tire charts I've looked at.
Thanks.
Old Apr 4, 2014 | 10:22 PM
2024 GLE63s
I looked it up in the owners manual (novel idea!)
7.5" front
8.5" rear
Old Apr 5, 2014 | 08:30 PM
jkiddd33's Avatar
2005 E55 AMG
Thanks.
7.5 and 8.5 is factory on my 05 clk55.
The tires that are on it now are 245 up fronts and 275 in the rears. (personally i wouldnt put the 245 up front however the previous owner did and there seems to be no issues)
YES ideally 275 on a 9 however you can run 275 on a 8.5.. I am with NO issues.
If you have stock wheels and no suspension mods, 235 up front and 275 in the rears will give you no issues what so ever.
Old Apr 6, 2014 | 10:18 AM
2024 GLE63s
^ thanks. Maybe I'll try 265's.
Old May 23, 2014 | 03:05 PM
ambit's Avatar
09 CLK550
Installed Pilot SuperSports last week on the stock 18" AMG rims
235/40/18
265/35/18
no issues so far
Old May 24, 2014 | 10:22 AM
0zranvest's Avatar
2007 clk550, 2006 clk500 (sold)
I run 265/35/18 conti DSW on 2007 clk 550 rear. no issues, but I have repros 18X 9.5 wheels .... read the board as several posts about Goodyear Fusion 265s had some rubbing issues when car bottomed, thus maybe fusions are slightly wider than contis. you can compare the width of your potential tires w/ the conti's and that should give you good answer.
Old May 24, 2014 | 10:32 AM
2024 GLE63s
235/40/18
265/35/18
no issues so far
I did too, Conti DW's.
No rubbing but........ now i have this weird issue where the ESP kicks in on the front if I do any hard cornering.
I take the canyons to work daily and it was not doing it before the tire size upgrade, now the yellow triangle blinks like crazy on hard corners. It really bugs me. I figure there is some sort of ESP confusion because the 265's are slightly larger diameter than the stock 255's. Ive asked on this forum and searched the 203 forum - I can't figure out if you can reset the learning curve of the ESP computer.
The off the line traction is much better - but the ESP issue makes me with I stuck with the stock 255's
