Engine Swap
Old Dec 17, 2014 | 10:10 AM
SBundlez's Avatar
2011 E350 4matic
Engine Swap
Since my car may have the dreaded balance shaft issue with my clk350, i was contemplating doing an engine swap since since the car is so old and they're cheap now (kinda). does anyone know if I go from the v6 to the v8 if i would have any issues? if so what would they be? would i have to change the sams? or would everything be pretty much plug and play?
Any assistance would be appreciated.
Old Dec 17, 2014 | 10:22 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, I can tell you if $4K to fix the balance shaft sounds a bit high, then get ready for some big bucks to replace the V6 engine with a V8. Not only do you have the cost of the engine, you'll need a matching transmission and I believe a new differential. Of course a new ECU, which will mean either new EIS or at least some reprogramming with SDS. Honestly, if you want a V8, you'd be better off selling the car for what you can get and buying a CLK550.
Old Dec 18, 2014 | 01:26 PM
tw2's Avatar
tw2
Its always cheaper to buy the car you want than modify. Balance shaft looks challenging but not impossible to replace if you have some mechanical skills.
Old Dec 18, 2014 | 09:44 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Agreed - if you can pull the engine, then the balance shaft replacement is a cakewalk.
Old Dec 19, 2014 | 02:07 AM
tw2's Avatar
tw2
If i read correctly you don't actually have a failure? I wouldn't even worry about it unless it happens. Only a small portion of the affected range will have defective shafts/sprocket (many factories made the same part) and many of those have probably gone a very long way without failing.
Old Dec 19, 2014 | 01:58 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Definitely not worth the swap. You say may have? So if it actually doesn't show up I wouldn't worry about it.
Old Dec 30, 2014 | 05:35 PM
SBundlez's Avatar
2011 E350 4matic
i have the P0016 P0017 issue. swapped the sensors on both sides to see if it was them and the issue still came up on the same side. Is that not the balance shaft? If not what else could it be?
Old Dec 30, 2014 | 06:11 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you have P0016 and P0017 OBDII codes, then I am fairly certain you have balance shaft failure. Like I said earlier, if you are equipped to pull the engine for a swap, then replacing the balance shaft (the revised part is a permanent fix) is just a little bit of "bench work" with the engine out.
Old Dec 30, 2014 | 07:07 PM
SBundlez's Avatar
2011 E350 4matic
so what tools would i need besides an engine hoist?
Old Dec 30, 2014 | 08:04 PM
tw2's Avatar
tw2
Someone made a 25 min video on YouTube of their e350 balance shaft fix. I read and watched a few things when i was considering an SLK350, very helpful. Just normal hand tools i think plus torx and inverted torx.
Old Dec 30, 2014 | 08:11 PM
SBundlez's Avatar
2011 E350 4matic
do you have the link?
Old Dec 31, 2014 | 12:36 AM
tw2's Avatar
tw2
Search M272 intermediate shaft and you should find a few videos. This is the one I watched, mainly just commentary and opinions in 2 parts. It was just to satisfy what would be required if I got a SLK350 in the affected range as a second car.
The actual fix doesn't seem like a big deal at all. It is just the labor removing the engine and putting it back in. Of course there are other expenses like replenishing all the fluids and I am sure there are other preventative repairs that would make sense to perform at the same time. I have no idea but you might also need specific tools to set the timing but Rodney can advise you on that account.
Old Dec 31, 2014 | 08:55 AM
SBundlez's Avatar
2011 E350 4matic
Thank you..... do i need to change the timing chain with it? it looks like that might be kind of difficult
Old Dec 31, 2014 | 03:10 PM
tw2's Avatar
tw2
I doubt it is necessary but if you have high mileage and want to do everything possible. It should all be fairly easy with the engine out. Get a copy of WIS from ebay if you don't already.
Old Jan 1, 2015 | 09:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My dealer, who did the job on my CK550, replaced the timing chain. The tech said even though it's not indicated in the TSB, they do it as a precautionary measure. Sort of like how you generally replace the water pump when doing a timing belt on a typical FWD engine. Some people also will replace the oil pump, too. My dealer said they only do that when they find pieces of teeth in the oil pan.
