Aftermarket Stereo for 2005 CLK 320 (and other questions)
Old Jun 1, 2015 | 07:11 PM
ConceptPlayer's Avatar
Clk 320
Looking for aftermarket stereo for CLK 320. That will fit in without complicated wiring! The dash looks like:
I have been reading around the forum but I need some guidance. All I want is an AUX input. I tried getting the AUX in cable (A210 440 50 05) but I don't have the input for it. Any other options?
Also, what are some easy aftermarket upgrades I can do? I already did tints and rims. I was thinking of
Backup Radar System Backup Radar System
? Anything else?
Thanks!
Old Jun 1, 2015 | 11:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There are lots of options - any double-DIN aftermarket unit will fit. Assuming you don't have the Harmon-Kardon system, or don't want an external amp, wiring is easy. The challenge is in finding the W209 version of the faceplate kit - most places sell the W203 kit and claim it fits, but it does not. It can be modified to fit, but the W209 "facelift" kit is best,if you can find it.
Old Jun 2, 2015 | 10:09 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Yup this is the one that fits:
http://www.ebay.com/itm/CT23MB04A-MERCEDES-BENZ-CLK-2006-2010-W209-D-DIN-FASCIA-FACIA-ADAPTOR-KIT-/160899063648?pt=LH_DefaultDomain_3&hash=item257654df60
Old Jun 2, 2015 | 05:49 PM
Eojj's Avatar
W209(sold), W212, X204
I believe if you have the CDC button on your console, you should have aux input. You should check inside the right side of your glove compartment for a aux jack or a hole. There's a YouTube video that shows you how to connect the aux cable through the passenger side panels
Old Jun 5, 2015 | 04:05 PM
Clk 320
I did and I do have the hole in the glove compartment but the wiring for the aux input is not in 2005 models for some reason.
Old Jun 6, 2015 | 01:50 AM
DanielFD's Avatar
2007 BMW 550i
Its actully very easy to add the aux cable if your willing to pull apart the dash and plug a wire into the back of the radio
Old Jun 6, 2015 | 02:03 PM
bstleve's Avatar
W209 CLK 320 CDI
Well, you're right, it is easy... once you know were you have to plug the new connector. The web didn't help me a lot
Anyway, you just have to pull out the original white connector, and plug the new one into the black frame (connector 3), and then to insert the frame into the Audio 20.
Then, AUX input will be available by holding the CDC button one second or so.
Bertrand
Old Jun 7, 2015 | 08:06 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
Did you check behind the access panel? Open the passenger side door and pop the panel on the side of the dash, side of the glove compartment. If you are luck you should have the AUX cable hanging there.
Old Jun 7, 2015 | 08:08 PM
omega48er's Avatar
This thread might help
https://mbworld.org/forums/clk-class-w209/532445-ecs-tuning-auxiliary-input-wiring-harness-your-clk.html
Old Jun 9, 2015 | 12:22 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
251 mm
It took quite a while but the Chinese have finally introduced the correct size Android unit for W209. Most still claim the 261mm for the 203 will fit but they are simply full of it as 251 is correct.
Available on Ebay about 550 shipped and it looks pretty nifty. Improved display and supposedly 4.4 O/S.
Old Jun 9, 2015 | 12:38 PM
omega48er's Avatar
But, I don't think they support that fiber connection.
Old Jun 9, 2015 | 01:41 PM
I think that is correct
The seller supplies a workaround patch cable.
I don't understand how it can interface with the COMAND system so the steering wheel buttons work.
Old Jun 9, 2015 | 03:23 PM
omega48er's Avatar
Can you like the one you are referring to. I'm still considering selling my clk550 if I don't I might do a sound system
