Brakepad wear indicator
Old 07-28-2015, 08:05 AM
demidion's Avatar
2007 CLK550
I have a 2007 CLK550 cab. does anyone know if the brake pad wear indicator is an actual sensor or is it a mileage based indicator?
Thanks!
Old 07-28-2015, 11:54 AM
abqhudson's Avatar
2018 C300 4 Matic
Sensor that wears thru. Look at the brake pad thickness every once in awhile and change the pads before the sensor wears thru - so that you don't have to replace the sensor.
Old 07-28-2015, 01:46 PM
demidion's Avatar
2007 CLK550
Oh !#!@~! the sensor wears through? Crap additional cost
Old 07-28-2015, 03:18 PM
briterfuture's Avatar
05 CLK320 , 15 Durango, 07 RX330
Brake pad sensors
The brake pad sensors are on both rear & front passenger side brake calipers. I recently replaced all 4 rotors, pads and sensors. Fairly easy replacement.
Briter Future
Old 07-28-2015, 03:48 PM
demidion's Avatar
2007 CLK550
It's good to know it's easy to replace!
Thanks!
Old 07-28-2015, 06:32 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
$10 a piece as I remember and takes 3 secs to replace when youre doin the pads.
Old 07-29-2015, 11:11 AM
TechSuperstar's Avatar
15' CLS400
Just let it break.. $10 for the sensor is better than doing them when the stealership tells you that you only have 20% left and that it should be done
Old 08-18-2015, 04:12 PM
DangermouseCLK's Avatar
2005 CLK 320
Is there 1 sensor per pad, or 1 sensor per wheel?
I am about to replace front brakes (4 pads), so do I need 2 sensors or 4 sensors?
Old 08-18-2015, 07:46 PM
abqhudson's Avatar
2018 C300 4 Matic
1 sensor.
Old 08-18-2015, 11:11 PM
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
There are usually two sensors on the vehicle - one on the front left, one on the right rear (or at least, I think those are the usual locations).
Old 08-20-2015, 06:28 AM
SIGagain's Avatar
2007 CLK350 Cabriolet
is everyone using OE rotors, pads and such or has anyone had a good experience with any after market stuff recently?
Bill
Old 08-20-2015, 10:16 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I have drilled and slotted Frozen Rotors and Porterfield pads. It's a good combination, but the pads are not quite as good as OEM in terms of stopping performance, but they are virtually dust-free. I'm probably a few months away from needing pads and I'm going back to OEM. I tried Akebono pads and HATED them - noisy and poor (borderline dangerous) stopping.
Old 08-21-2015, 07:39 AM
SIGagain's Avatar
great information...thank you Rudney...
Bill
Quick Reply: Brakepad wear indicator
