Any Fix for Off-Center Steering Wheel?
As you can see in picture (inside the red circle), the top and bottom markings are slightly to the right (clockwise).
Does anyone know how to fix this?
It's pretty easy to fix at home yourself. Just adjust each tierod the exact same amount - say 1/8 turn - and check how it drives. The trick to know which way to turn both of them to get the correct adjustment of center and not to botch it up, which cause your car to be out of alignment.
Regardless, I think the OP got his answer...and a lot more.
Get a good alignment, they should be able to adjust the tie rod ends to keep the wheel in the center position.
Regardless of that, the proper way to re-center the steering wheel is with a proper road wheel alignment.
