replace or repair transmission
Old Jan 10, 2016 | 05:01 PM
tae.one's Avatar
CLK500
When I gas the car I hear a rattling noise that I initially thought was the catalytic converter. I had it lifted up and verified it is not the catalytic converter but the sound is coming out of the transmission. I took the car in to a guy who basically told me it is something in the transmission that it needs to be rebuilt- approx $4k. Looking around I see plenty of transmissions for about $700. Would it be better just to swap out the transmission in this case? I ask in case I'm missing something about MB that would complicate things.
Old Jan 10, 2016 | 09:02 PM
kb24forlife24's Avatar
None for now
What year is the car?
Old Jan 10, 2016 | 09:04 PM
tae.one's Avatar
CLK500
2004 clk 500
Old Jan 10, 2016 | 09:38 PM
fastlife23's Avatar
Cl 65
4K for a rebuilt trans? have you shopped that around?
Old Jan 10, 2016 | 10:38 PM
tae.one's Avatar
CLK500
No, not yet. That could be an option to look for a better price. I think what I am looking for is,
- Price of used transmission + installation (is it something I can DIY).
-- I've seen transmissions for less than $700
-- How much would installation be? Can I do it myself? There is a Benz dealership nearby, along with mechanics that work on Benz in the area.
- Price of repairing current problem
-- Can I fix it myself?
-- How much should I expect to pay?
I do have a garage with space to do the work myself. I have plenty of tools and do not mind buying more to get the work done within reason.
Old Jan 11, 2016 | 12:49 AM
Yidney's Avatar
2008 CLK550 Cab
Forget doing either a swap or repair yourself. Does your tranny work ok? Usually if one makes a noise that loud it also is not working correctly.
Old Jan 11, 2016 | 02:49 AM
tae.one's Avatar
CLK500
The transmission is fine...it just sounds like it doesn't. It makes this sounds like making a rattling noise you hear on low rpm and gets drowned out on high. It sounds bad to me because I love the sound of the engine.
The mechanic that was trying to diagnosis the issue wasn't very exact about what the issue was. Something about the transmission bearing.
I think I'm going to take it to get diagnosed by MB.
Old Jan 11, 2016 | 07:17 AM
DanielFD's Avatar
2007 BMW 550i
Check your flex plate, it can cause sounds like that
Old Jan 11, 2016 | 09:40 AM
Yidney's Avatar
2008 CLK550 Cab
Going to MB will be the most expensive route. They can read tranny codes, but a bad bearing or flex plate will not throw codes. I might try an independent MB place or a good tranny place just to see if you can get a more reliable diagnosis.
Old Jan 11, 2016 | 10:13 AM
tae.one's Avatar
CLK500
I'll check out the flex plate locally at an independent shop.
https://mbworld.org/forums/clk-class...isc-plate.html
According to this thread you need the car on a lift to diy. Unfortunately, I do not have access to one.
Old Jan 12, 2016 | 09:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Does it do this in park/neutral? If so, I'd lift the car and use a mechanic's stethoscope to isolate the exact location.
Old Jan 13, 2016 | 12:12 AM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
I agree with the other guys. I run a transmission shop. Dont go to a general auto repair for a diagnostic.
it does sound like a broken flexplate. If there are no codes and working fine i doubt its the trans.
As for a used trans. i have done allot of them on mercedes for auto warranty companies. They want the cheapest route. If you find out it is your trans and you want to go that route message me. I will tell you what company to buy one from. They are national company and give the best warranties on their products. Its the only place i buy used parts from
Old Jan 13, 2016 | 11:45 AM
tae.one's Avatar
CLK500
Thanks. I'll jack the car up probably today to take a look at the flex plate. I'll determine then if I want to attempt it myself.
I'll also be cleaning the MAF and replacing the air filters. The car has been bogging, dropping rpms and almost turning off. I want to address that also. The idea is to replace the plugs, wires, clean MAF and replace the air filters and see how the car is then.
Old Jan 18, 2016 | 10:32 PM
tae.one's Avatar
CLK500
I jacked up the car today to check the flex disc (not flex plate) and it looks fine. I noticed fluid on the transmission, but i don't think it is recent. I'll take this to a transmission guy when I have time. In the meantime, I will be working on the spark plugs & wires, replacing seat belt retractor and valve cover gasket.
I remember the guy i bought the car from said he serviced flex plate, but the guy who said he fixed it and has it under warranty said it is not the issue. Long story short, I had the car at his show for almost 3 months and could not even figure out the. My guess is he was jerking me around and didn't want to work on my car and would rather work on cars coming in for insurance work. So here we are...same noise and still no idea what the issue is.
The noise can be pinpointed to around the firewall at the passenger side leg area, towards the center console.
List of things to work on seems to grow on this car. I have everything else under control but this noise worries me.
Old Jan 18, 2016 | 10:41 PM
mbnz230's Avatar
2023 c300 4matic
i think you should use your phone or something to post a video so people might get an idea of how bad the sounds are.
Old Jan 19, 2016 | 09:59 AM
gixxerboy's Avatar
your really cant visually inspect the flex plate unless you remove the transmission.
Old Jan 19, 2016 | 11:25 PM
tae.one's Avatar
CLK500
I inspected the flex disc, not the flex plate.
I have the car in the garage until the seat belt retractor that I ordered comes in. Once I have that installed I can take out the car and record the sound that it makes.
Old Jan 19, 2016 | 11:27 PM
jamesbenz21's Avatar
c230
4k for a rebuild? we do them at my mercedes shop for around 2500
Old Jan 20, 2016 | 10:12 AM
gixxerboy's Avatar
You are way under charging on a 722 trans.
Old Jan 22, 2016 | 11:09 AM
c230
i've mistaken.. with all the updated parts itll be around 4k. the rebuild is not hard just time consuming as a tech
