Change headlamps to HID
My 2006 CLK 350 came with halogen headlights, which I hate.
Please help me with the needed parts.
I can get the HID headlights from a couple of eBay sellers:
$199 http://www.ebay.com/itm/Driver-Side-...ZWVe2v&vxp=mtr
$529 set http://www.ebay.com/itm/Bi-Xenon-HID...lWsdTc&vxp=mtr
$492.96 set http://www.ebay.com/itm/Bi-Xenon-HID...tWsP-7&vxp=mtr
eBay also sells the ballast parts, not sure all I need.
There are also several eBAY sellers with used OEM HID headlights, and one that has brand new for $693 per side.
Any help would be appreciated
But I call bull on Plug and Play. First the drivers side turn was all that was working on that lamp, the high beam on the passengers side. Tried the original halogen back on the drivers side and the passenger HID and turn signal started working.
I finally told them to take the positive off the battery, waited 10 seconds and every thing worked!!!!
Well worth it though. But the instructions should say disconnect the battery positive EVERY time. Photos to come later as car is dirty from 78 MPH winds with a light rain.
It will fit inside your existing headlight without conversion at a fraction of the cost. ($12.95 for the pair) They also have a high beam one and fog light as well.
Back before HID and LED I put some eBay special higher wattage headlight bulbs, and they burned out in the middle of the night on a trip. Fortunately I had kept the original bulbs, but not easy to change when dark!
You drive a Mercedes... don't do stupid things like this, or really ANY vehicle.
Blue tinted bulbs are ****. If you don't believe that look up Daniel Stern and read. You will be amazed at the info.
Going cheap is normally half assed way of doing things from experience.
If you are tight for cash look on ebay for OEM projectors. I scored OEM projectors off a crashed clk55 for $108. I then took them completely apart, painted them, polished the outer lenses, got ZKR clear projector lenses and changed the HID bulbs. I have superior lighting over OEM projectors IMHO.
If you like DIY projects do a projector retrofit. Check out hidplanet's forum and your mind will be blown with how much information is out there and how many people can help you out in the process...
Lighting is something that one shouldn't go cheap with.
-Nigel
