Wheel alignment recommendations
Here is the spec sheet (I hope it uploads correctly)
Looking at the specs I should probably have an alignment thought the car drives straight as an arrow. The wear on the front tires was quite noticable on the outside edges. The rear tires had incredible wear on the inside edges. So this brings me to the rear camber question. Reading the forum I see our cars are designed with negative rear camber. I know there are adjustable arms that can take much of this out of the car. However, and this is where I get confused in the search for answers, it seems that replacing the bushings can bring the rear back into spec and possibly below -1 on stock suspension.
So my questions.
1) Did I understand what I read in the forums correctly and new bushings may get my rear right into a factory spec position thereby saving tire wear? I know some negative camber is necessary for performance in cornering and optimal camber is a preference type of thing. But dang those tires were worn heavy on the inside
2) Would it be better to forego the bushing replace and get adjustable camber arms? Sadly the K-Mac stuff is beyond my budget at this time
3) I know I need the alignment but would adjustment of that big cross caster pull me to the right horribly since it is straight as an arrow.
Thanks for your knowledge and opinions on this as I am just learning and am thankful for this forum for safe and trusted information.
And another https://mbworld.org/forums/clk-class...ml#post6720912
I have them on our clk and i know other members here have these arms also
