is it wrong to put glasspacks on a Mercedes ?
Old Oct 15, 2016 | 12:56 AM
irokdastar's Avatar
2004 CLK 500
I been toying with the idea of putting a glass pack on my car . any one here done that mod?
Old Oct 15, 2016 | 04:35 AM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
First of all, you can do whatever you wish to "your car".
Are you simply looking to add a glass pack or are you planning to use it to replace another exhaust component in your exhaust system?
I doubt that just adding one will make much difference.... BTW what is it you are trying to achieve?
Old Oct 15, 2016 | 06:00 AM
Merc Mania's Avatar
1985(W126)500SE, 1994(W124)E420 1991(R129)500SL and The Mothership 2009 CLK550
Unless I am mistaken, Fatz, glass packs are designed to drastically increase the amount of noise created by the exhaust plumbing of cars, without delivering any performance benefits at all.
Glass packs in a Mercedes exhaust will certainly get the attention of other motorists, though one imagines that not all other road users would enjoy that extra racket emanating from a nearby car.
Old Oct 15, 2016 | 11:08 AM
Fatz's Avatar
I don't think that inserting a glass pack between the engine and the resonator or muffler is going to do much. Maybe that is what the OP is looking for. They are designed to emphasize the low frequency tones in the exhaust; I just think the other components would negate most of the emphasis provided by the glass pack.
I don't know this as fact, but I believe glass packs are simply small diameter resonators with a straight-through exhaust flow. Since the diameter is small, there is not much sound absorbing material between the center pipe and its' shell. They could even have a small reflective cavity to emphasize the lows. Now you've stirred my interest; I'll have to investigate this weekend.
Old Oct 15, 2016 | 03:27 PM
PeterUbers's Avatar
People have and continue to do far worse to a Mercedes Benz .... live your life and be happy --- get your glass packs
Old Oct 15, 2016 | 04:33 PM
Wookii's Avatar
2013 E350 Wagon
Put them on. Enjoy for a week, get annoyed by the drone, put everything back to stock. Same as the muffler delete guys.
Old Oct 15, 2016 | 08:30 PM
irokdastar's Avatar
2004 CLK 500
well at the moment i have straight pipes right after the secondary cats .So i already have the noise just thought by adding them i can get it to sound better .
Old Oct 15, 2016 | 10:04 PM
Fatz's Avatar
Glass Packs may make it a bit louder in the low frequency range. It is hard to gage what you mean by sound better.
My opinions:
Do you want a more "muscle car" sound and rumble? Glass Packs will do that.
Do you want a smoother exhaust note? Vibrant resonators have a crisper/sharper note.
Do you want to lower the exhaust volume? A magnaflow or flowmaster muffler will do that. I believe both companies make straight-through and reflective (more restrictive) mufflers.
The longer a straight-through muffler or resonator the more noise attenuation there will be.
I assume you have a true dual exhaust setup....
Old Oct 16, 2016 | 10:46 PM
kb24forlife24's Avatar
None for now
Delete the secondary cats first
Old Oct 16, 2016 | 11:54 PM
JimVonBaden's Avatar
2005 CLK500
It's your car. Do what makes you happy!
Personally I like the sound of a stock CLK500.
Old Oct 18, 2016 | 12:07 AM
irokdastar's Avatar
2004 CLK 500
If I delete the secondary cats I am going to sound like an old chevy v8 . I heard a couple of v8s without cats and it sounds horrible
Old Oct 18, 2016 | 07:47 PM
None for now
That's your opinion, but I believe that you'll get a much more Mercedes-style sound with a cat delete vs. glasspacks.
Old Oct 20, 2016 | 01:34 PM
eteller's Avatar
2009 CLK 350
In high school we used to get them good and hot then feed a garden hose up the pipes and turn it on. It would break up the glass to get more RAAAASP!
Old Oct 20, 2016 | 04:05 PM
Fatz's Avatar
I think the "glass" in glass packs refers to fiberglass.
They are generally made with a small pipe inside a larger pipe with fiberglass between the 2 pipes. Like the secondary cats and resonators in our cars, they can be "ported" to achieve greater noise cancellation due to turbulence; similar to what you get when the engine expels into the exhaust manifold (there is much less turbulence with headers).
Old Oct 20, 2016 | 04:38 PM
eteller's Avatar
2009 CLK 350
Yep, and you break up that fiberglass and they get louder and more raspy. Great for a car with a 01 on the side, not so much for a Benz.
Old Oct 21, 2016 | 11:25 AM
irokdastar's Avatar
2004 CLK 500
I ordered the 12" and 23" . I am going to have the muffler shop just clamp them on to see if I like it before I install them . I will upload a video
Old Oct 5, 2019 | 10:20 PM
Harry Lime's Avatar
2014 Mercedes Benz C 250
So what is the final verdict? What did you do? Did you just add the glass pack behind the muffler or in place of the muffler?
Old Oct 6, 2019 | 03:09 PM
SwissKiss's Avatar
Black 2004 CLK (w209) 320 Cabrio auto transm. "Elegance" trim; <br /> 2014 A180 black man.
You do as it pleases you of course. Having heard a few modifyed MB exhausts recently at a car wash, I think it only makes the car sound like a bulldozer. Fine for a truck but a bit cheezy for a benz sedan
Old Oct 20, 2019 | 10:30 PM
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
Flowmasters like the delta flow with big pipes sound real melow. When you are cruising they sound nice and mellow, but when you stomp it they roar pretty nice.
