Aftermarket Audio system question
Old Nov 9, 2016 | 09:29 PM
zuzu_pali's Avatar
2004 clk500
I am putting new door speakers beyma . My question is how can I keep my original head unit ? I really don't want to buy another radio . Is their a way I can tap the wires to my original head unit ? I seen that I can't connect the wire from the new amp to the heady unit. If their is a way to do it id really appreciate it
Old Nov 10, 2016 | 10:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I assume you have the Bose system. Why are you replacing speakers? If it's because they are physically failing, then I's go with the OEM Bose speakers.
Old Nov 11, 2016 | 07:45 AM
zuzu_pali's Avatar
2004 clk500
Yes sir the bose system , the reason is because i want to go louder .
Old Nov 11, 2016 | 08:09 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
door speakers are not your answer. Swapping the head unit is the only thing that is really going to help. the systems in these systems run at a different ohm rating than normal aftermarket and they are a balanced output so you will need a converter to run an amp. Do some searching this has all been covered many many times
Old Nov 11, 2016 | 04:23 PM
91ser's Avatar
2003 CLK500, 2003 CLK55, 2008 CLK550
To answer your original question, yes, you can just replace the front speakers. And yes, it has the potential to go a little louder.
insame1 mentioned that the bose systems run at a different ohm rating than normal systems. This is true, as the bose systems use a 2 ohm rated speaker. Most car audio is 4 ohm. While most home audio is 8 ohm. This is simply a rating of their impedance or resistance. Here is a few examples of 2 ohm speakers you could use to replace the bose ones: 2 ohm speaker link
If you look at the equation for power, its P = (v^2) / R. So lets quickly compare why a 2 ohm system should be louder than if you put a 4 ohm speaker in. Lets just assume we have 12 volts to deal with.
4 Ohm
P = (12 volts ^2) / 4 ohms = 144 / 4 = 36 watts
2 Ohm
P = (12 volts ^2) / 2 ohms = 144 / 2 = 72 watts
1 Ohm (for fun, because this is what some subwoofers run at)
P = (12 volts ^2) / 1 ohm = 144 / 1 = 144 watts
So, if you just want to replace the speakers, make sure to find something that is 2 ohm. Now, to make it louder, you will either need a higher sensitivity of speaker, or just plain old more power. The sensitivity of a speaker might only change 1 or 2 decibels, so its not the most effective way to go louder. Really, if you want it to be louder, a new amp is really your best bet.
Old Nov 11, 2016 | 04:27 PM
91ser's Avatar
Now, to talk a bit about your second issue, the amp. The stock amps use a fiber optic connection. If you want to use an aftermarket amp with the stock deck, there are a few option.
1. You will need an optical to rca converter. This will convert the optical signal to analog rca which aftermarket amps can use.
2. Use the speaker line level input. The amp will literally take the input from the speakers as the input. In this case, that means keeping the stock amp as the signal to an aftermarket amp.
Old Nov 11, 2016 | 05:12 PM
zuzu_pali's Avatar
2004 clk500
thank you for all the good info bro. i might do just that. i have 4 6.5 inch beyma comp speakers and a amp hifonics 4 way . i bought a wiring kit for speaker wires and all the other wires needed.
Old Nov 13, 2016 | 07:38 AM
irokdastar's Avatar
2004 CLK 500
I just did a conversation and replaced the speakers and headunit . It depends what year car you have I'd you have 03 to some 06 they do not make the fiber optic to analog converter . And those converters are a couple of hundred dollars . Which means you can buy a brand new headunit and have SD caRd and back up cameras. To do the entire system is easy and will give you the best bang for your buck . You just need a good headunit like pioneer , kenwood , jvc etc, 5 ch amplifier to power the speakers and subwoofer . You just run rcas from the new headunit to the rear on the driver side and on the passenger side you run the amp wire . If you use rcas the signal is cleaner than using a hi low converter .
Old Nov 14, 2016 | 02:57 PM
91ser's Avatar
Ive never even heard of Beyma, who carries them?
Agreed with irok, the hi - low converters work, but typically have more noise than directly using rcas.
My last system was a Pioneer AppRadio2, CDT 6.5 comps in front, Image Dynamics 10" sealed, and Massive Audio amps. Sounded really great! Pretty simple but sounded great.
Old Nov 14, 2016 | 03:27 PM
irokdastar's Avatar
2004 CLK 500
Just want to add the rear speakers are 6" not 6.5 and you will need a coaxial speaker for the rear not a component . The front are 6.5 and would fit ok . let us know what route you end up taking.
