switched 12 v driver side fuse box
Old Dec 13, 2016 | 12:14 PM
irokdastar's Avatar
2004 CLK 500
I am trying to find a switched 12v in the driver side fuse panel . My multimeter gave out on me so I don't even have that to check . I am trying to wire my radar detector that I mounted under the mirror .
Old Dec 13, 2016 | 01:12 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Cigarette lighter in the middle. There's no switched only constant at the fuse box. I ran a wire from the rear SAM to have switched in that spot.
Old Dec 13, 2016 | 02:24 PM
irokdastar's Avatar
2004 CLK 500
Ok I guess I am going to have to run it to the cigarette lighter . Thank you
Old Dec 14, 2016 | 09:26 AM
BenzAMG99's Avatar
C63s
just curious, what kind of radar detector do you have?
Old Dec 14, 2016 | 03:13 PM
irokdastar's Avatar
2004 CLK 500
whistler
Old Dec 14, 2016 | 10:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I have an Escort and installed it with the hardwired cord with remote mute. I wired into the cigarette lighter and put the mute button on the center console, then routed the power line under the dash, up the A-pillar and across the top of the headliner/windshield to the detector.
Old Dec 16, 2016 | 10:50 AM
irokdastar's Avatar
2004 CLK 500
that's what I did and I thought I would be able to tap into the fuses on the driver side . on a convertible its a bit harder to do because I have to open the top and take of the plastics that's under the top and remove the driver shade .
Old Dec 16, 2016 | 10:53 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, dealt with that rim on both the CLK cabriolet and the SL. It's an hours job, but worth the trouble for a clean install.
