What did you do with your CLK today?
Old Jun 11, 2019 | 08:26 AM
  #151
C280 Sport's Avatar
MB’s of all kinds.
Originally Posted by mcgsxrclk500
I had a rear view camera installed. I had previously had an aftermarket head unit put in, and recently popped the $ to have steering wheel controls added. During that work I bought a reverse camera, but did not have the time to have it completed at that time.
Works well, especially useful with the roof up.
I did not want one that attached to the license plate, as I have issues with the 4 bolts that hold that on, and did not want anyone removing and replacing those.
So a not quite stealthy install, but I'm fine with it.
Nice job! Any pics of the headunit?
Old Jun 11, 2019 | 08:27 AM
  #152
C280 Sport's Avatar
MB’s of all kinds.
Did a Service A on my 2009 CLK. Road trip ready to Florida on the 25th. When I get down there my 2004 CLK will need a service A as well. So Service A's all around. CLK55 is good.
Old Jun 11, 2019 | 10:42 AM
  #153
mcgsxrclk500's Avatar
2005 CLK500 Cabriolet
I will get a pic of the view from the camera on the head unit, but here is a pic of that JVC installed.
Old Jun 11, 2019 | 08:27 PM
  #154
Hard to contort myself in the car to avoid glare with the roof down. Should have pulled it out and put the roof up I guess.
Old Jun 12, 2019 | 08:24 AM
  #155
labguy's Avatar
Veteran: Army
2014 E350 Sedan; 2025 GLB 250
Originally Posted by xsever
How many miles/km on it before the bearings needed changing?
I had my Indy change my bearings at 125K miles. It needed it. Much smoother now.
Old Jun 12, 2019 | 11:42 AM
  #156
megacrazy's Avatar
CLK55 W209, CL63 W216
My parking brake had been sticking for a while. I decided to beat some sense into it. Lifted the rear seats up, took off the fabric cover, opened the access hatch and cleaned everything with some WD40 while furiously pumping the parking brake pedal. I also turned the middle nut a couple times clockwise which fixed the slight slack in the cables. All good now. Took about 20 mins and was very easy.
Old Jul 18, 2019 | 04:19 PM
  #157
clydem's Avatar
2005 320CLK Cab
Did some preliminary investigating on the 320CLK convertible
We had heavy rain & downpours here in NNJ. She called to say her back seat had a lot of water in it & she was worried.
It was the passenger seat, so tomorrow is clean, test, and if all is well, give the car a good waxing and 303 waterproof the roof again.
Old Jul 19, 2019 | 03:29 PM
  #158
Did some focused clean up this week.
Cleaned the wheels (Sonax) and waxed them. Then vacuumed the interior.
Struggle to get the interior of the windshield clean without streaks, but working on it.
Black cars look great when they are clean - however long that lasts!
Old Jul 19, 2019 | 09:06 PM
  #159
Fatz's Avatar
2008 clk550 - Navigator - Frontier
I've found that using just tap water on the inside of the windows works best. You can add a drop or two of dishwashing liquid if you like. Use a microfiber towel. I have a small 2-3 oz sprayer which makes it easier to not spray anything else. Not that it would hurt anything else.
Old Jul 20, 2019 | 09:28 PM
  #160
clydem's Avatar
2005 320CLK Cab
Try a Mr. Clean Magic Eraser sponge. it works pretty well. I haven't tried their disposable sheets yet.
Vacuumed thoroughly as well. Used leatherique on the seats & dash. In this heat, I'm letting it soak in for a day or two.
Old Jul 22, 2019 | 10:10 AM
  #161
Anker's Avatar
2009 CLK 350
Now that the heat wave is over I'm going to perform 80K service on the CLK350. Service A, but with spark plug change.
Old Jul 25, 2019 | 11:52 AM
  #162
SwissKiss's Avatar
Black 2004 CLK (w209) 320 Cabrio auto transm. "Elegance" trim; <br /> 2014 A180 black man.
Brought to order a stubborn soft top reluctant to open. Not that I would open it by 40°C under the south of France sun. Rounded up all the usual suspects ending with... the easiest culprit: relays grrrrr
Wrote a summary about in a separate thread: https://mbworld.org/forums/clk-class...em-solved.html
Old Jul 25, 2019 | 12:04 PM
  #163
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
Diagnostic testing
Hooked up the clk550 to xentry and did some testing. Compression check shows low compression in # 2 cylinder. Hopefully it's just valve spring issue, and not rings/valves
Old Oct 3, 2019 | 01:33 PM
  #164
spaulhus's Avatar
12 E350 Cabrio & 19 C300
Tme for some maintenance...
2008 CLK 350, 96,000 miles - time for some maintenance...
- Replaced intake manifold assembly
- Replaced leaking left cam adjuster magnets and cam position sensor o-rings
- Replaced clogged passenger washer nozzle
- Replaced oil filler cap
- Replaced front thrust arm bushings
- Replaced front struts and mounts
- Performed 4 wheel alignment
Old Oct 9, 2019 | 08:25 PM
  #165
Fatz's Avatar
I've noticed a reduction in steering response over the past year. It got to a point that I noticed understeer during quick maneuvers and though it was due to wearing front tires - not to the wear bar. There has been a pop/plunk sound occasionally when I first come to a stop after having the car jacked up from one side. The steering wheel became off-center. The tires were replaced a few thousand miles ago and aligned.
This week had the steering rack bushings replaced and realigned. Tremendous difference. Response is immediate and accurate. I had bushings replaced because I am recovering from illness and I didn't feel up to it but it could be a DIY if you can press off the4 bushings. There were four bushings replaced. They are metal with a rubber covering. Mine were badly worn (184K miles). Two were worn to where the inner metal was visible. The bushings are about 25-40 dollars each and took about 3 hours labor + $100 for alignment. BTW if you have someone to rock the steering wheel you can see that the steering rack rods (through the rubber boos on each side) move up and down instead of just side to side.
