2004 CLK 500 future Maintenance Cost and Mileage Life?
Old Jan 30, 2017 | 10:53 PM
faran's Avatar
2004 CLK 500 with AMG Package, Not Convertible
Guys, I have been contemplating to sell my CLK500 with ~81K miles. I know there are some guys out there with 'high mileage' and I am looking to them to seek their help and advice.
So far I had the car for over 4 years and it has been trouble free, but its not my DD either. I bought from 1st owner with full maintenance records and history.
Since I had it, replaced all fluids( PS, Coolant, Brake Fluid, ATF, Differential, engine oil), filter( including transmission), serpentine belt( as a precautionary measure) and air filter. For PS used a syringe to suck old and pour fresh fluid. Brakes have a lot of meat, rotors are good too. All pads/rotors were replaced around 65k. CPS(crank positin sensor) has been replaced by PO, as well as all spark plugs. Tires are good too.
All other hoses and suspensions components, fuel filter, radiator, mounts, I believe are 'Original'.
My question to you folks is, what else I would be needing to replace in near future? I do majority of stuff DIY. How much maintenance cost I should be looking at? Then I'll decide if I should keep or sell her?
Thanks for all of your inputs and help.
P.S: Transmission shifts very smooth and engine is quiet. Have dropped the pan for ATF, replaced filter, cleaned up everything well. Then again drained and refilled ATF after 5-6k miles.
Old Jan 31, 2017 | 01:57 AM
xsever's Avatar
2012 C300 4MATIC Sport
I have a 2005 CLK 320 with 156,000 km on it (97,000 miles) and I've done all the maintenance you mentioned except for the CPS. I bought the car when it had 99,000 km (62,000 miles) and I plan on driving it for 1-2 more years.
On top of your maintenance, I did the following:
- Engine Mounts
- Transmission Mount
- AC Compressor
- Front and rear control arms
- Front and rear stabilizer bars
- All 4 shock absorbers + mounts (nothing was broken, I just wanted to refresh the suspension)
- Drive Belt Idler Pulley ($15)
- AC Footwell stepper motor ($75)
- Catalytic Converter ($230)
- Oil Cooler seals
- Valve Cover Gasket
- EGR Valve ($30)
- Coolant Reservoir ($37)
I live in Lebanon hence the prices. I wouldn't get rid of it if I were you given how reliable it's been. You may only need to replace suspension wear and tear items just like I did.
The M113 Engine and the 722.6 Transmission are bullet-proof!
Old Jan 31, 2017 | 07:55 AM
faran's Avatar
- Engine Mounts
- AC Compressor
- Oil Cooler seals
- EGR Valve ($30)
Thanks xserver, appreciate it.
Few follow up questions, please:
1- All engine and transmission mounts a DIY or can be a pain? Is there a DIY/youtube video for it?
2-Front lower control arms or upper and again, they are a DIY? Is there a DIY/youtube video for it?
3- Front stabilizer bar, an easy DIY?
How much was the price for these components, just a ballpark? I am sure, it'll be a bit cheaper here in the states.
Old Jan 31, 2017 | 08:11 AM
xsever's Avatar
1- Transmission one yes is an easy DIY, the engine ones I am not sure since I have the M112 so there could be less space for the M113 engine. I bought the 2 engine mounts and the 1 transmission mount as a package for $141 from Amazon.
2- For these, you need a special tool to remove some parts as my friend mechanic said so I doubt these are DIY for the whole job. Lower and upper arms are about $100 (US prices) so $400 for both sides at the front.
3- Yeah this one I would is a DIY. Front one was $100 and rear one was $90 (US prices).
Old Jan 31, 2017 | 08:26 AM
faran's Avatar
Thanks again xserver
1- Mind asking which brand did you use and happy with it? Any symptoms of these mounts going bad?
2- Yeah, it might be that a press is need or a fork too or maybe something bigger?
3-Again which brand and happy with them? Any symptoms of them going bad?
So in a nutshell if I consider just front parts, then I be looking at ~$700 in parts and that's not bad at all!!!
Thank you
Old Jan 31, 2017 | 08:31 AM
xsever's Avatar
Thank you
1- https://www.amazon.com/dp/B00QXK2D8S...=ID5Q5FKQP2GDU
Very happy with them and no sign of wear yet. The difference when I changed them was huuuuge (yuuuuuge )! The car got so much smoother.
3- Original Mercedes parts and yes very happy with them. The squeaks were all gone and I could feel the ride got firmer. When I did all the suspension work, the car basically felt brand new again!
Old Jan 31, 2017 | 08:38 AM
faran's Avatar
Thanks again, very helpful.
Few more things, you have never touched tie rod ends and any of the coolant hoses, yet?
Or any other sensors or alternator? Thanks
Old Jan 31, 2017 | 08:45 AM
xsever's Avatar
Yes I have replaced tie rod ends when I did the front suspension work.
NEVERMIND, scratch the above. The tie rods were not replaced. It's the stabilizer links that were replaced in the rear. I mixed up the two.
No coolant hoses, no sensors, and no alternator replacement.
Old Jan 31, 2017 | 08:58 AM
faran's Avatar
Thanks man, adding it to my action list
Old Feb 1, 2017 | 09:43 PM
mis3's Avatar
2004 CLK320
I drive a 2004 CLK320 with high mileage all driven by myself. I went to an indie to replace the transmission and engine mounts. He told me that the left engine mount was difficult to replace because of limited space.
I perfer genuine MB parts.
Old Feb 2, 2017 | 11:37 AM
faran's Avatar
Thanks mis3.
Mind asking how many miles on your car? And what parts have you replaced on the car so far?
Old Feb 3, 2017 | 12:28 AM
mis3's Avatar
2004 CLK320
I have 220k miles to this car. I bought it new in Dec-2003. Of course, I had no idea that I would keep this car for so long.
In 2016, I replaced a driver side seatbelt, transmission cooling lines, low beam bulb, third brake light, hood support struts etc. Back in 2015, I replaced the driver side window switch, one trunk spring.
Old Feb 3, 2017 | 08:31 AM
faran's Avatar
Thanks very much guys.
I appreciate input from xserver and mis3, at least I have a general idea in terms of the things it'll need and associated cost with it.
Think, I am going to keep the car for 1-2 years and when it'll become a money pit, then will think to get rid of her.
Old Feb 3, 2017 | 01:49 PM
mis3's Avatar
2004 CLK320
This goes to all older cars. It will eventually become a money pit. My 2004 CLK320 does not worth much anymore but since it drives so well, it is a shame to trade it in for so little money.
For instance, I was not at all discouraged while I had to replace the drIver side seat belt. This w209 is my daily commute and based on my rough calculation, at the minimum, this seat belt was used (extend and retract) for 40,000 times! Same for the driver side window switch assembly.
On the other hand, if the rear window switches fail (almost never used), I would be discouraged.
Recently I had to replace the 3rd brake light, I was impressed (also annoyed) with the 12 rivets holding the trunk lining. On a lesser car, there may be 6 rivets which actually would be suffice.
Old Feb 3, 2017 | 03:01 PM
faran's Avatar
I agree with you completely and hence I asked the question about maintenance, to wait till value of the car hits rock bottom or sell since it'll be prudent.
I still have a few days to think about it, but overall maintenance doesn't look terrible and am glad that I have done proper maintenance so far
BTW, mis3, have you ever had to replace the ATF electrical connector which goes into ATF pan?
Old Feb 3, 2017 | 03:55 PM
mis3's Avatar
2004 CLK320
I am afraid that our cars (both 2004) have hit rock bottom or at least close to it!
By ATF electrical connector, did you mean the conductor plate?
Old Feb 3, 2017 | 04:05 PM
faran's Avatar
Yeah anything related to conductor plate or this part(https://www.amazon.com/URO-Parts-203...vert-amazon-20)
Have you replaced anything on the suspension? Like tie rods, shocks, struts, ball joints or control arms or anything along those lines?
You are so right about the rock bottom, but I am glad that I bought it 'used' hence not losing too much. If you know what I am saying?
Thanks for all the help.
Old Feb 3, 2017 | 05:35 PM
mis3's Avatar
2004 CLK320
Oh. You are talking about the 13-pin electrical connector. This is a surprising inexpensive parts, I paid only $13CAN in local MB dealership. For engine and transmission parts, I would definitely go by genuine MB parts. I do not change this connector at every ATF pan change, it is quite difficult to replace with the concerns of bent pins.
As for the othe suspension components, I am sure I replaced most of them in the past years. Last suspension components I replaced were the sway bars, front and back.
I bought my w209 new and it has been my daily driver ever since. I think I got my money worth!
Old Feb 3, 2017 | 05:59 PM
faran's Avatar
That is surprisingly an inexpensive part, finally! Lol
BTW, so I assume you have changed it at least 2-3 times so far? Have you ever touched the conductor plate or no?
Honestly, that's what I feel in terms of worth of the money!
Old Feb 3, 2017 | 06:06 PM
mis3's Avatar
2004 CLK320
I recall that this 13-pin connector was replaced at least twice.
The conductor plate was replaced back in Jul-2013. The mileage of the car was 174K miles at the time.
Old Feb 3, 2017 | 06:21 PM
faran's Avatar
Got it, thanks very much mis3. I am going to replace this connector on my next drain of ATF.
Keeping my fingers crossed for conductor plate, hopefully have a long way to go!
Old Feb 3, 2017 | 06:38 PM
mis3's Avatar
2004 CLK320
Good idea. I remember there was a revision on this 13-pin connector. some of the early version leaked.
When the conductor plate fails, you will know. Search for limp mode in this forum.
Old Feb 3, 2017 | 06:44 PM
faran's Avatar
Thanks, yeah my local stealer is asking for $26 for this connector
I'll order online and will replace it. So far no 'Limp mode' and hopefully never
Got it in terms of the conductor plate issues. Thanks again for all of your patience and help.
I am keeping the CLK based on all the 'math', thanks again guys.
Old Feb 3, 2017 | 07:12 PM
mis3's Avatar
2004 CLK320
I know of a few online stores which sell original MB parts. Oediscountparts sells it for $12US. Buy a few more iiems to qualify for free shipping.
https://www.oediscountparts.com/part...&siteid=215242
http://www.rmeuropean.com/Products/2...253-MFG22.aspx
Old Feb 3, 2017 | 09:16 PM
faran's Avatar
Thanks mis3, you da man
