Brake comparison (mostly weight comparison)
Old Sep 6, 2017 | 03:31 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
Want to share some information regarding clk (and compatible) brakes. Hope that someone will find it useful (had to use different scales)
#1 Original 2004 clk320 rotors (rotors are almost new, don't know exact brand):
Front - 17.85lbs - 300mm - vented
Rear - 10.02lbs - 290mm? - solid
#2 c32/c55/clk500/clk550/clk55(prior 2005) rotors (rotors are new, StopTech Slotted):
Front - 26.45lbs - 345mm - vented
Rear - 15.21lbs - 300mm - vented
#3 clk55/slk55 (2005) rotors (rotors are new, Front - Brembo, Rear - original Mercedes, most likely Brembo as well):
Front - 22.48lbs - 340mm - vented
Rear - 18.73lbs - 330mm - vented
Attached Thumbnails Brake comparison (mostly weight comparison)-clk320_front.jpg   Brake comparison (mostly weight comparison)-clk320_rear.jpg   Brake comparison (mostly weight comparison)-32_front.jpg   Brake comparison (mostly weight comparison)-c32_rear.jpg   Brake comparison (mostly weight comparison)-clk55_front.jpg
Old Sep 6, 2017 | 03:40 PM
dzmitry's Avatar
#1 Original 2004 clk320 calipers + pads (pads are almost new, don't know exact brand):
Front caliper - 13lbs (most likely ATE)
Front pads - 1.88lbs
Rear caliper - 6.8lbs (most likely ATE)
Rear pads - 0.87lbs
Attached Thumbnails Brake comparison (mostly weight comparison)-clk320_front.jpg   Brake comparison (mostly weight comparison)-clk320_front_pads.jpg   Brake comparison (mostly weight comparison)-clk320_rear.jpg   Brake comparison (mostly weight comparison)-clk320_rear_pads.jpg
Old Sep 6, 2017 | 03:47 PM
dzmitry's Avatar
#2 c32/c55/clk500/clk550/clk55(prior 2005) calipers + pads (pads are new, EBC Ultimax 2):
Front caliper - 10.2lbs (Brembo)
Front pads - 1.7lbs
Rear caliper - 6.77lbs (most likely ATE)
Rear pads - 0.75lbs
Attached Thumbnails Brake comparison (mostly weight comparison)-c32_front.jpg   Brake comparison (mostly weight comparison)-c32_front_pads.jpg   Brake comparison (mostly weight comparison)-c32_rear.jpg   Brake comparison (mostly weight comparison)-c32_rear_pads.jpg
Old Sep 6, 2017 | 03:56 PM
dzmitry's Avatar
#3 clk55/slk55 (2005) calipers + pads (pads are new, Original Mercedes)
Front caliper - 9.85lbs (Brembo)
Front pads - 3.11lbs
Rear caliper - 5.55lbs (Brembo)
Rear pads - 1.89lbs
Attached Thumbnails Brake comparison (mostly weight comparison)-clk55_front.jpg   Brake comparison (mostly weight comparison)-clk55_front_pads.jpg   Brake comparison (mostly weight comparison)-clk55_rear.jpg   Brake comparison (mostly weight comparison)-clk55_rear_pads.jpg
Old Sep 6, 2017 | 04:41 PM
dzmitry's Avatar
Some visual comparisons:
1,2 - clk55/slk55 front caliper vs w211 (almost exactly as c32) caliper
3 - clk55/slk55 rear pad (on the left) vs c32 front! pad (on the right)
4 - clk55/slk55 rear caliper vs clk320 rear caliper
Attached Thumbnails Brake comparison (mostly weight comparison)-2.jpg   Brake comparison (mostly weight comparison)-1.jpg   Brake comparison (mostly weight comparison)-3.jpg   Brake comparison (mostly weight comparison)-4.jpg
Old Sep 6, 2017 | 04:42 PM
dzmitry's Avatar
Before and after shots
Attached Thumbnails Brake comparison (mostly weight comparison)-6.jpg   Brake comparison (mostly weight comparison)-5.jpg   Brake comparison (mostly weight comparison)-7.jpg   Brake comparison (mostly weight comparison)-8.jpg
Old Sep 6, 2017 | 08:08 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Very nice information to have!
Old Jan 17, 2018 | 11:51 AM
coladin's Avatar
2014 C63 507, 2012 R350
delete lol
Old Jan 17, 2018 | 01:05 PM
dzmitry's Avatar
Originally Posted by coladin
People are yelling at you while you drive because you are driving like a moron in a busy downtown area of Toronto. I don't know how your buddy doesn't throw up with you rocking that car back and forth with your throttle. Honestly, the car sounds nice, I get that. But you really should calm down in those high pedestrian areas. Or get a room with your exhaust and make love to it.
I'm sorry are you talking about me? I've never been in Toronto
Old Jan 17, 2018 | 01:22 PM
coladin's Avatar
lol I have zero clue how this posted here, apologies! I was on a C43 forum for Pete's sake
Old Jan 17, 2018 | 01:31 PM
dzmitry's Avatar
Old Jan 18, 2018 | 03:06 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
Excellent pictures and information.
Crazy how much larger the AMG/Brembo calipers are compared to stock. I swapped our sport brakes on our w211 a year ago for AMG/Brembo calipers. I took a picture of just the calipers for comparison. The AMG are truly gargantuan. They make my STi's brakes look tiny as well.
-Nigel
Old Jan 18, 2018 | 07:31 AM
tjts1's Avatar
C320
I swapped out the stock 300mm brakes on my C class (same as CLK320 brakes) for 312mm w211 E500 4 piston brakes which fit inside 16" wheels. They weigh exactly the same.
https://imgur.com/a/3T7cz
Old Jan 18, 2018 | 03:13 PM
dzmitry's Avatar
-Nigel
And difference between stock 1 piston vs 6 piston just wow!!! Brakes on my 16 Camaro SS not even close to these AMG brakes
