DIY - How to remove IR sensor (w203, w209) - without cutting anything!!!
Old Sep 8, 2017 | 11:20 PM
aleks001's Avatar
2002 C200 Kompressor Elegance MY03
Everyone STOP CUTTING YOUR DAMN KEY LOCKS TO REMOVE THE IR SENSORRR!!!!!!!!
I don't understand why the internet has gone down this road and that no one has figured out how to remove the sensor nicely. How do think Mercedes got the sensor in there, they sure as hell didn't build the lock around it.
There are two pins that you just pull out and the front face of the lock comes out and then you simply slide out the sensor.
The pins however can be annoying, one of mine I had to drill out, for it's replacement I just cut a nail to about the size of the pin and put it back in the whole.
Big thank you to whoever the hell it was on the internet that figured out that all that was required was the soldering of the pins for the auto/open close function.
As you can see in the photos there are some scratch marks, this is from me trying to work out what was holding the lock in, you wont get this if you just remove the pins. It was annoying having to drill one of the pins out, if someone figures out a better method to pull these *******s out will save everyone a little headache.
Old Jun 20, 2020 | 02:56 PM
Csikker's Avatar
Mercedes C200 kompressor
IR sensor roll pin remove without cut or drill
I posted here, how to remove roll pins easily without cutting and drilling.
https://mbworld.org/forums/c-class-w...ml#post8086833
Old Feb 22, 2024 | 06:12 AM
Esko Kupiainen's Avatar
2001 E430 4matic
its in the first 25-32s on the video. oops its for w220
Last edited by Esko Kupiainen; Feb 22, 2024 at 06:15 AM. Reason: wrong imfo its for w220
