N103 ( A2098203226)
mercedes CLK500 W209
N103 ( A2098203226)
Hi, we are looking for the place where is located on my CLK W209 , the N103 ( A2098203226) Calculator....?
It suposed to be placed near the Gear selector, but we dont find it ...!
Somewone can help please ?
thanks .
thanks .
I think that part number is the keyless go module. If so, on my car it is in the trunk, at the front behind the rear seat under a large metal cover that looks like a step. Lots of electronics under there. Your part number is different than mine though. Sometimes electronics are not in the same place depending on year and model. What years is your car and is it a coupe or convertible?
N103 module on CLK W209 last génération (2005-->)
keyless go module in CLK W209 last génération
Thanks, i'll tale a look and tell you 😊👍🏼
My CLK is a 500 coupe last génération produced in 2005....Thanks, i'll tale a look and tell you 😊👍🏼
Thanks, but we get out all the central console and there is not KG module (A2098203226) ...
when Mercedes is questioning my car serial number in VIS , this module is référenced ...!
the Star Diagnose indicates that all the antenas are working and that the key is reconised... but only the rear KG ( bagage) is working...??!
doors and ignition on the gear selector do not work...!?
Testing this problem it appers that the N103 module is not responding....
i want to change it but we don't find it ...
my car have the Distronic.... I think that the KG module is on an other place...but where ??
MBworld Guru
Are you looking for something with that specific part number stamped on it? That probably won't work because the numbers stamped are often not the same as the EPC part numbers. Go by looks and location. Here's the WIS doc for removal, with another photo:
http://benzbits.com/w209/KeylessGoInteriorModule.pdf
From the photo, I though the module was behind the shifter somewhere, but the Benzbits photo shows it as clearly visible when you pull up the wood. I'm pretty darned sure I don't have anything there. Rodney, you may recall the other little antenna module somebody was looking for a few months back where MB showed it on the left rear and I posted a pic of mine on the right rear. So god knows where this thing actually is located.
MBworld Guru
Maybe it moved, but there is a KG antenna in the center console - it has to be there to properly triangulate the location of the key so it can be detected to start the car and also so that the key is not locked in the car.
