W209 convertible roof material problems?! Help
ive purchased a clk convertible and when the roof retracts the material around the sides of the rear window bulges out, I’ve tried tucking it back in however soon as the roof is dropped it pops out again
On mine the liner has a metal strip that goes into a channel around the rear window. At one point the strip popped out of the channel. It could be pushed in again and would stay in place for a while, and would then pop out again. I assume there is some kind of adhesive is used to keep it in place and decided that Show Goo would be a good fix. It has held so far.
From the OP's description it sounds like it could be this problem, since the liner will bulge where it has detached.
Take a look at this
http://benzbits.com/w209/soft_top/Canvas.pdf
Around page 3 is where they talk about attaching the straps to the frame. If you will stop the top operation with the rear glass raised, you can then prop it up with something (I used a cardboard box) and then you can inspect the area. Look for a strap that attaches to the water bag but is hanging loose. It likely ripped off of it's rivet where it was attached to the frame.
