2007 Clk 350 issues after wrong synthetic oil change
checked engine code code got a pooo19 camshaft,crankshaft position sensor b bank. Also got mis fire fro, 4.5.6. Replaced camshaft sensor. Same issue. Need help in identifying the issue. Thanks
You should change both the magnet and the sensor.
You may want to pull more codes to isolate the problem before throwing too many parts at it......
