CLK 500 Engine Idle
Old Aug 11, 2004 | 09:05 PM
RJC's Avatar
RJC
Various
Exclamation CLK 500 Engine Idle
I've recently noticed the idle on my CLK 500 varies with the AC on. When at full operating temp, in gear, with AC on its either 700 or 500 and varies every other traffic light or so. When it is at 700 if I turn the AC off it drops to 500 but if I switch the AC back on it stays at 500, if I rev the engine or drive a few more miles it will be back up to 700; shouldn't it go back up on its own while stopped or without reving?
I know the idle raises and lowers when the compressor kicks in with some older cars but I never noticed it in the CLK before as I always thought it stayed at a constant rpm when the AC was on.
I recently had the ECU changed due to the engine cooling fan staying on high speed so I'd really like to know if my car is behaving like other's here.
Please post your observations.
Old Aug 12, 2004 | 09:24 PM
RJC's Avatar
RJC
Various
Anyone???
Old Aug 15, 2004 | 12:54 PM
RJC's Avatar
RJC
Various
Unhappy
Wow! The ressponse has been overwhelming, thanks to everyone for providing the feedback I needed I always try to help out other forum members when I can
Old Aug 15, 2004 | 02:31 PM
AznxKCBoy's Avatar
2004 Mercedes Benz CLK 500
sorry, this has not happened to me yet..cant give any feedback for you.
Old Aug 15, 2004 | 04:24 PM
RJC's Avatar
RJC
Various
Thanks for the reply. I'm curious to see how other cars idles are with A/C on in gear and at a stop; 450 rpms 650rpms etc. and does it vary? This info will be valuable when I visit the service dept on Tues.
Old Aug 15, 2004 | 05:05 PM
AznxKCBoy's Avatar
ok ill be going out tonite, after i drive it in a bit..ill put my car idle and then turn AC on and see if there is a difference. I'll post after!
Old Aug 15, 2004 | 07:23 PM
Kar don's Avatar
Mercedes-Benz
LOL RJC, I probably think its ok. You could bring it up to your dealership if it wasn't doing that before the new ECU but my guess is that the compressor was engaged as you were slowing down which made the idle up at 700. If you turn on and off the A/C at a stop the compressor might not kick on right away.
Old Aug 15, 2004 | 11:11 PM
RJC's Avatar
RJC
Various
Thanks!
Old Aug 15, 2004 | 11:19 PM
RJC's Avatar
RJC
Various
Hey Al. I wish what you were saying was all there was to it but since the ECU was changed my car idles normally about %75 of the time and the other %25 lower at around 400-450. I'm almost certain the car never did this before and that's why I need the feedback.
The other thing that made it obvious was it would be at 700 with the AC on and if I hit the econ button it would drop to 400 but when I turned on the compressor even after waiting a while it never went back up again until I reved the engine...something's not right
One thing fixed and they screwed up something else; ahh the pleasures of visiting the service dept.
Old Aug 16, 2004 | 11:23 AM
Kar don's Avatar
Mercedes-Benz
That really sucks, I hope they can find it and its an easy fix!
Old Aug 16, 2004 | 08:15 PM
RJC's Avatar
RJC
Various
Unhappy
Thanks Al.
Well on the way to the office the car almost died at the first traffic light, it stuttered and stumbled then cleared but unfortunately no malfunction light. I asked a colleuge that drives on 03 500 to check his car out at lunch and he said his idle when warm is always at 650/700 with or without the AC on or off.
Lets see what the good MB doctor says tomorrow; now I've got to protect the stone interior in case the grease gremlins strike.
Old Aug 16, 2004 | 08:35 PM
Guest0001
Guest
Posts: n/a
Is this your second CLK500 you are on right? It seems you are not having much luck. Sorry to hear.
Old Aug 16, 2004 | 09:02 PM
RJC's Avatar
RJC
Various
Yes the first was an 03 that had ALL the first year bugs.
Old Aug 17, 2004 | 03:07 AM
calboy's Avatar
2003 CLK 320
Well, I checked out my car and the engine idles at ~500 whether AC or not...hope this helps
Old Aug 17, 2004 | 09:54 AM
RJC's Avatar
RJC
Various
Thanks for the info ...it helps.
Old Aug 17, 2004 | 06:48 PM
AznxKCBoy's Avatar
sorry..didnt post sooner, was busy. I am the same..when I have AC on or not when the car is idle it still stays at around 500 rpms.
Old Aug 17, 2004 | 08:51 PM
RJC's Avatar
RJC
Various
Thanks. That's what I thought; it shouldn't change.
Well I got it back today from the dealer and they raised the rpm up by 40 and it seems to be much better now. The car idles at +/-700 in gear with AC on and say +/-690 with AC off. The Tech said that they installed an 05 ECU last time I was in and it has slightly different settings than the 03 and 04's. I don't know if that's BS or not but they offered for me to do a side by side comp. I think my idle was too low after they put in the new ECU and the computer sensed it most times and brought it back up most of the time, so maybe they extra 40 rpm was just enough to keep it out of the danger zone. There were no codes from the car stumbling the other morning and I'm glad it's better now.
I saw a new 05 500 coupe and I/m not too sure about the new rim design again??? The center stack is nicer for sure as is the stock 55 deck spoiler.
There was also a red 05 55 CLK and the split spoke 18"s really helps the looks of the car, the new giant brake calipers and quad exhaust are to die for but the sticker was $78K... that's the base price of the new 997 Carrera S!!! I think I'd rather have a base 2005 S, what do you guys think?
Old Aug 17, 2004 | 09:30 PM
AznxKCBoy's Avatar
ya for that kinda money i would get a carrera s..that is such a nice car.. but then again, i rather triple that 78k and get a gt2
Old Aug 17, 2004 | 10:40 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
997 is hot - I'm planning to get the 997TT when it is released (hopefully 06). I'd skip the S, but I guess it just depends what you want out of it...
