Differential seal ?
Old Aug 9, 2020 | 06:53 PM
irokdastar's Avatar
2004 CLK 500
Differential seal ?
My axle seals are leaking and I decided to change both sides . I got new seals and dust caps as recommended by Mercedes . I will need to remove the diff cover to get access to the C clamp . Does the Differential ave a gasket or do I need RTV . Thanks in advance .
Old Aug 10, 2020 | 01:26 AM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
You are gonna need RTV. What c clam are you talking about?
Old Aug 13, 2020 | 06:15 PM
irokdastar's Avatar
2004 CLK 500
Inside the housing that holds the shafts in place .
Old Aug 13, 2020 | 06:21 PM
dzmitry's Avatar
I see, the only things which holding axles inside the diff are small snap rings, you don't need to remove them, simply pry axles out.
Old Aug 13, 2020 | 06:23 PM
dzmitry's Avatar
You can find some useful pictures here https://mbworld.org/forums/clk-class...e-install.html
Old Aug 13, 2020 | 07:01 PM
irokdastar's Avatar
2004 CLK 500
When I looked it up on WIS it showed that I needed to open the rear diff cover and remove a C clamp . Can anyone confirm this ? I have a 2004 CLK500 convertible with 722.6 . I appreciate all the help
Old Aug 13, 2020 | 07:19 PM
dzmitry's Avatar
Any chance that you looked at a wrong place?
Old Aug 16, 2020 | 05:44 PM
irokdastar's Avatar
2004 CLK 500
I defiantly did lol . do I need any specialty tools to tackle getting any of the suspension or components out ?
Old Aug 17, 2020 | 04:34 PM
dzmitry's Avatar
Not really, the only thing I can think of is if you are going to remove axles from knuckles, then to undo axle nuts you are going to need big socket and torque wrench which can handle about 200 ft/lb torque to torque them.
Old Aug 17, 2020 | 07:50 PM
irokdastar's Avatar
2004 CLK 500
ok , do I need to use a puller once I get the nut off to separate the hub from axle ? Thank you for all the help
Old Aug 17, 2020 | 07:54 PM
dzmitry's Avatar
Yep, but you don't really have to remove axles from knuckles, in my thread I showed how to remove an axle with knuckle, the only problem is to disconnect parking brake cables.
Old Aug 20, 2020 | 12:41 AM
irokdastar's Avatar
2004 CLK 500
Thank you
Old Aug 20, 2020 | 07:28 PM
irokdastar's Avatar
2004 CLK 500
i tried searching for your thread and I couldnt find. Do you have a link by any chance ?
Old Aug 20, 2020 | 11:41 PM
dzmitry's Avatar
Sure, it's https://mbworld.org/forums/clk-class...e-install.html. To be clear this thread is about installing LSD, but I went throughout the same steps you going to.
