Uh oh? 2004 CLK320 Tranny Issues (P0715)
Have you experienced this?
P2203 - Y36n3 (Speed sensor No. 3 is faulty)
P220A - Speed comparison of Y3/6n2 to Y3/6n3 is implausible
P2066 - fault stored in component N15/3 (EGS controller). (OBD 2 code P0715)
I hear this can be one of the sensors on the conductor plate or an oil-soaked TCM. Any other possibilities?
-Sensor 3 reads 0 when the vehicle is stopped. Sensor 2 shows speed/RPM when the car is in Park or 1st gear and the vehicle is stopped.
-Sensor 3 shows speed/RPM when in motion in gears 1-4. The reading appears to lag Sensor 2 a bit when initially taking off from a standstill (not sure if that's a quirk of the Foxwell or actual behavior). Sensors 2 and 3 quickly sync up once the vehicle is in motion for a few seconds.
-Sensor 3 reads 0 when in 5th gear. Manually shifting to 4th gear, Sensor 3 shows speed/RPM again (synced with Sensor 2). Sensor 2 always shows speed/RPM while in motion.
Is this the expected behavior?
After about 200 miles, the car went back into limp mode with the same faulty Sensor 3 code. The live data showed that the sensor was reading 8000RPM fixed and the current gear suddenly became “IMPLAUSIBLE”. So, the 8000RPM reading is the failure mode for this sensor, not 0. I cleared the code and the car came out of limp mode and has been good for another 150 miles.
Will drive more to see if I can replicate the failure.
https://mbworld.org/forums/clk-class...ice-costs.html
