Brake Booster Vacuum Hoses - Part ID
What is:
- the name?
- the function?
- the termination of the other end?
- part number, if known?
In my ‘04 CLK it has chafed through with a 1/2 inch section carved away. Length is still intact.
Further: Transmission will only shift out of Park when started if done immediately, in sequence.
- Brake depressed
- Ignition to Start
- Immediately move selector lever
If there is a delay, it will not allow shift.
If returned to “P” with engine still running:
- With brake depressed and held it will allow shift into and out of “P, no problem.
- If brake is not depressed, it will not allow shift out of “P”.
Manual Shift Release works just fine.
Shift pattern/behavior while driving is correct.
Opinions and experiences welcome.
Please identify the “white hose/line”.
I have 2 each 2001 ML320 (same engine/same transmission), neither have this small white line coming from the brake booster vacuum port.
but i remember that vaccum line is used also for headlamp adjustment.
did you received the mail with the PDF of the brake booster assembly?
Any ideas?
I know the black plastic pipe is from the vacuum pump. What’s the grey pipe for that goes in to the fuse box from the servo?
here in italy gasoline benz are rare specially 500, 550 and 63. 2.2 CDI are full
2.7 Liter is rare here where I live
For my Original Post: The small white tubing at the brake booster provides 'power' for the rear-passenger headrest "Fold" action. It is a vacuum actuated latch initiated from a dashboard switch. (The 'hint' for it's purpose was from a suggestion on another forum.)
(Always keen to learn more about these early-aught MB's. I have 5 total and love them all.
2000 CLK320 22,000, 2001 ML320 (Designo, and a Sport) 190,000 on each, 2004 C230 SportsCoupe 114,000, and 2004 CLK320 72,000)
Not sure I'm gonna stretch to Cat deletes though.
it looked suspicius grey was not factory. I wonder if that affect the vacuum pump for brakes
