Feedback/Opinions on '05 GTO
Thanks all!
Heck in stock trim you might be able to give an E55 or SL55 a good run
. Check the review on Stangnet.com http://www.stangnet.com/2005-Mustang...00-by-SVT.htmlSVT Ford Dealers I hear will be taking orders in Jan 06
Ref the website as follows http://www.autoblog.com/entry/1234000297052050/
2 guys at work have these and I must say they drive nice and feel good on the inside too.
That would be nice!
IMHO the GTO is a way to get a 400hp engine and a starting platform for a fine performance vehicle. It is VERY heavy. It needs suspension and brakes to be truly reguarded as sensational.
It has LOTS of body roll, but stiffer shocks for quality damping characteristics and a very good ride. It does handle better than most vehicles so it is entertaining. Although it is very much overpowered for the limited grip levels and the amount of body roll that results from high speed cornering.
The brakes are not up to the task of high speed stops. They offer good feel, and work ok for spirited driving, but if you push this car it will fade fast.
The auto box has limited gear ratios with a very tall 4th gear overdrive, and is not at all effective for anything but straight line motoring. It is however a great 4L65E trans that will handle gobs of power and torque if you want to drag race it and modify it.
The Tremec T-56 6speed manual is very strong. It is a little ropy in feel, but it does just fine. It is a close ratio 4 speed with two overdrives. Top speed is attained in 5th. 6th is ridiculous and is almost not ever used. If you could, it would probably go over 300mph in 6th if you had the power the way it is geared. It is more than adequate for high performance driving, and it is my favorite way to drive the GTO. Cluth takeup is light, and it is easy to crawl through traffic, barring "skip-shift".
The interior is exceptional in finish. It has FULL leather interior using THICK leather, and REAL suede door inserts not synthetic. It also has REAL satin nickle finish trim, and THICK nicely grained plastics. The 200W 10 speaker Blaupunkt stereo is very dissappointing. It is not loud, not clear, and has lots of buzzing speakers.
Overall for a daily driver or something you will not race, it is a great value. If you do wish to modify it this is an even better value since you already have a great motor and trans. I know the owner of a Pontiac dealer so if you do want one I can hook it up.
I hope this helps. This is just my take on the GTO, and had the money to spend on a great all around very fast car with a REAL backseat and an 18.5 gallon fuel tank with 25MPG avg EPA on the highway I would totally buy one.
straight it was dead even, on the twisty stuff i was much faster, i couldnt pass though b/c we were on a 2 lane canyon road.
i think it was all down to my driving though, the car hang nice, needs some wider rubber and shorter sidewalls.
nice car overall, very good bang for the buck and loads of cheap aftermarket parts
That said, while I love the fact that they put a corvette engine and gertrag transmission in this new one, I'm sorry the body styling just isn't a GTO. It looks more like a tricked out sunbird than a re-make of the old classic, and I hated it. They would have been better off calling this the new MONARO, because it's certainly a fine car.
Why couldn't they do what Dodge did with the new Charger and made a true GTO? Heck, they could have used the cts-v platform and gotten pretty close to the original.
I instruct for MBCA and Audi Club of NA and did about 15 track events with the GTO. It definitely has the power. But like barw211e320 mentions it needs some tuning in the suspension and brake areas. For '05 it gets Corvette C5/C6 front brakes and vented rotors in the rear. With venting to the front brakes they are adequate with street/track pads. For the suspension some of the OE rubber bushings need changed to poly and shock/springs recalibrated.
The problem with bringing over a car not designed for the US is that the suspension has the travel length of an off road truck. This was to accomodate the Aussie's not-so flat roads. So the spring perch is right on top of the tire. Hence going with widder rubber, the wheel size needs to be decreased. Coilovers are the only solution.
I ran 13.2 @ 107 MPH with about 5000 miles on the clock. The engine is the same as the Corvette C6 and so is the torque management, especially in lower gears. With a few bolt-ons and some tuning 400 wheel hp is possible. For $29K with 400 hp and having a back seat too there is not much out there in the price range. Look for Dodge's 425hp SRT-8 with 4-doors to cost $10K more and only have the option of an automatic.
Norm
