CLK55 Thermal Cold Air Intakes Completed
Old Nov 28, 2005 | 12:57 AM
robertus's Avatar
CLK55 AMG 2006 Cabrio, BMW M3 2008 DTC Cab new (M3 e46 SMG 2003 Cabrio Sold), BMW X5 tt Diesel 2008
Have just finished the second half of the installation of Thermal covers.
Attached Thumbnails CLK55 Thermal Cold Air Intakes Completed-q1.jpg   CLK55 Thermal Cold Air Intakes Completed-q2.jpg   CLK55 Thermal Cold Air Intakes Completed-q3.jpg   CLK55 Thermal Cold Air Intakes Completed-q4.jpg   CLK55 Thermal Cold Air Intakes Completed-q5.jpg
Old Nov 28, 2005 | 12:59 AM
robertus's Avatar
This the fabric that was used.
Old Nov 28, 2005 | 01:47 AM
zaint10's Avatar
SL 6.1 Brabus, E55, SLK55
Awesome!
Can it be done on SLK55 using the same fabric? Where can I get them and how to install them? Thanks
Old Nov 28, 2005 | 02:02 AM
robertus's Avatar
Hi zaint10.
You should be able get the fabric from any Thermal covering company, try the ones that make thermal blankets for Turbo Chargers etc. All they do is cut out the shape of the two cold air intake tubes from the fabric (tubes just pull off the car) and then sew them together.
The thermal covers then just slide over the plastic air intake tubes.
The back part of the intakes you use silicone gel (use the silicone rated to 205 degrees Celsius) to stick the fabric to the plastic. Do not use glue as you cannot get it off the plastic, also the glue cannot stand the heat and lets go.
It cost me all up around $150.00 Australian
Old Nov 28, 2005 | 02:42 AM
Josh K's Avatar
Tesla Model S
Looks great!
Old Nov 28, 2005 | 08:02 PM
Co 55 AMG's Avatar
W208
Wow, that look,s Sano!! Nice set-up.
Old Dec 13, 2005 | 06:38 PM
joeybenz106's Avatar
2007 cls 550
how well does it work?
Old Dec 13, 2005 | 10:58 PM
robertus's Avatar
Hi,
They work really well. After driving around the city & suburbs you could not touch the plastic air intakes they were so hot. Now as soon as you stop and lift the bonnet they are only warm to the touch. Best thing I every did.
We run the car on 100 octane fuel with 5% ethanol blend, have Green Filters and a larger exhaust system, we completed a total of 740klm (350klm country drive & balance city freeway to work at around 100-105k per hour), we use exactly 60.0 litre's of fuel and I had to really squeeze that into the tank. That's about 8.1 litre's per 100klm or around 30-31 miles to the gallon. They say that the 100 octane fuel will give you up to 15% better economy.
I think its also the fact we are getting cold air into the engine all the time, it runs one bar cooler on the temp gauge as well. On a full counrty run I would say we may get a bit better but I think the saving is in the suburb driving because on the cool air getting to the engine.
