Ran against a C55 in the quarter mile....**crappy VID**
That being said, I raced an acquaintances 2005 C55 with less than 10k miles on it and beat him. My all-seasons don't grip for ****!!!! My 60' times were horrendous:
My time (W209 CLK55): 14.2 @ 100.69 mph (2.35 60' time)
Hist time: 14.3 @ 102.11 mph (2.2 60' time)
I forgot to bring out my new camcorder, so I had a buddy use my POS digi-cam (normally used for still photos).
Surprised your trap speed isn't a bit higher....this could be partially due to the 60', but I'd also check your tire pressure and use better gas next time...good luck!
Bone friggin' stock. Want to recommend a starting point? Does an intake and exhaust actually do anything to these cars?
I've always been confused about that--why is the C55 lighter when it has two more doors???
A GOOD set of tires. In fact, I personally would get drag radials (I'm a bit extreme, thats why I would get drag radials). Just the rears, as thats all you need for a rwd. A LSD to help out with the launch, and a suspension set up. To get a good launch, you need softer springs and shocks, that way, when you launch the weight is shifted to the back, and pressure is put on your rear tires. Thus making them grab without spinning. Coilovers would be great for that. At the strip you make it softer, so you can get great launches, and on the street you make them a little harder to get great handling.
The 1/4 mile is all about the launch. You can have all the power in the world, but if you don't have good traction, then you're time won't improve much at all. The strip is not long enough for you to be able to make up for bad traction.
If you want to improve both, 1/4 mile and top end, then I'd suggest to make the car breath easier. Do intake, headers, exhaust, downpipes, get some lighter pullies, and a tune. Intake and ehxuast won't do you too much if thats the only thing you get. You will still have the headers and downpipes restricting you before the gases reach the exhaust. I personally would do headers and downpipes before the exhaust, just to get the gases out of the engine as fast as possible.
Loosing some weight and adding a 50-75 shot of nitrous never hurts.
Here's another run between me and my buddy in his clean E36 M3:
http://s12.photobucket.com/albums/a2...2006011avi.flv
Also, nice sig pic, too.
Funny, I thought the C would weigh more, too, because it's a sedan.
That makes no sense....is the CL heavier than the S Class?
I'm confused as to why a two door version of the same car would weigh more than the 4 door counterpart....
When did you go to the track? What time did you arrive at the track and how many runs did you get in? Also, what rpm did you stage at for your launch?
Allan
Allan
I went last Friday for the "Midnight Drags" at Rocky Mountain Raceway. It's pretty ghetto and most of the cars are just 18 year olds with riced out civics--but it's the only time I had available to drag race. There were a couple of Porsches and Vipers, however....
I tried several different methods--but my tires don't grip at all, so I basically could only powerbrake to about 1400 rpms or I would simply peel out too bad when the light turned green.
The guy in the C55 said he could powerbrake to about 2500 rpms and not lose traction....apparently he just put on brand new Pirelli P Zeros with a lot of grip. They're also a lot wider than mine are (I have skinny 245/45/17's)....
I'll PM you before I go out next time....it'd be cool to line up against each other and get it on tape!
Brad
As for the CL vs. S, here's their weight from Consumer Guide ('06 model)...
CL = 4085 lbs.
S = 3980 lbs.
Wow again...the S-Class is over 100 lbs. lighter. Amazing!
i wonder if the W208 CLK430 is heavier than it's 4 door W210 E430 counterpart........
I am shooting for the 09/22 midnight drag but I will have tire issues as well. I wouldn't mind the practice as I haven't been for about 5 years and that was at the New England dragway. It would be good to run the to cars together if possible but my memory of stagging was that this difficult. Could you arrange it with you buddy in the C55? Just email me at allan@lawdesk.com next time you go and I will see if I can make it.
Allan
The C55 weight in at 2115 kg and the new CLK63 weight in at 2175 kg. The CLK63 is probably lighter than the CLK55 it replaced.
two door version of the car are usually heavier because they need to strengthen the structure hence added material. Especially with the CL and the CLK which doesn't have the B-pillar. Same reason any convertible is going to be heavier than the coupe.
back to topic, the time C55 and the CLK55 posted are nearly identical, but the C55 traps faster due to less weight. The time doesn't tell much actually because they only start to time it when you leave the line, so one may react quicker and still post a slower time. Due to many reason, traction for one. You may react slower, but hook up quicker for better time slip, and he may react quicker, but still fighting for traction. my only conclusion is that C55 will edge out the CLK55 and you both can get better time with practice. LOL. oh yea, I don't believe he/C55 can powerbrake at 2500rpm without losing traction. I've drove friend's C55 with PS2 and it doesn't take much to brake traction. Hell, my car doesn't even powerbrake that high without losing traction and I don't have that much torque even with the pulley.
He outlaunched me and mid way through second gear I started pulling ever-so-slightly. Every other gear was pretty much dead even.
Thanks for the comments, guys!
