W209 CLK 55 suspension question
Subscribe
Oct 4, 2006 | 03:52 PM
hi guys
i just got 2003 clk 55 coupe
and i am thinking to change suspension..
any recommendations?
thank you
Reply 0
Oct 4, 2006 | 07:05 PM
what is your budget?
Reply 0
Oct 4, 2006 | 11:25 PM
I have been thinkin' the same. I was thinking euro springs and pads so they are compatible with the car and wont cause warranty issues.
How much are they (googled and cant find it) and where can I buy them /have'em installed?
Thank you very much guys.
Reply 0
Oct 4, 2006 | 11:54 PM
PSS9
http://66.155.125.17/forums/showthread.php?t=153775
Reply 0
Oct 5, 2006 | 05:04 PM
Suspension Change
Try Kleemann . I personally install a set in my car. It was easy. The drop was 25.4mm / 1" . The ride quality remain very good . over bumps. No problems with with steep driveways. or parking lot speed bumps. They worked well for me. But I did install a pair of Speedy Benz Camber bars. Had the rear camber set ,on the right & Left & Toe in,on the right was off justa little. On the front end , just reset the toe in. I've put 5000 miles on since then and the tire wear is prefect.
Reply 0
Oct 5, 2006 | 06:56 PM
can you just change the springs with h&r's? im picking up my 55 on monday! and was also curious about this.
Reply 0
Oct 5, 2006 | 07:23 PM
Gratz CLK22 !.. Are you close to Boston or live in the 'burbs?
Reply 0
Oct 5, 2006 | 10:09 PM
THanks! i live in waltham and am constantly in lexington and arlington.
Reply 0
Explore
Oct 6, 2006 | 03:19 AM
by the way, i only found H&R SPORT is available for clk 55..cannot find H&R RACE
Reply 0
Oct 6, 2006 | 08:23 AM
If you are interested in Euro-Spec springs then check this thread out:
https://mbworld.org/forums/showthrea...o+spec+springs
It has all the info you need.
Reply 0
Oct 10, 2006 | 06:18 PM
I agree. PSS9s.
Reply 0
Subscribe
Currently Active Users (1)
