Project Chrome Dome.
#101
sounds like airplane
actually, all I need to know is how to take the upper half of the intake apart.
Got intake off car and separated and got the 4 screws out- scared to yank on it too much. How does that "inside" come out?
#102
I posted a reply in your other thread. Basically I had to heat it up and then gently pry the pieces apart while tapping the outside of the mani (where the glue bonds would be) with a plastic mallet and you could hear the glue cracking away. After a while you should be able to gently pry it the rest of the way apart. Just take it easy and use your head.
#103
How to disassemble my manifold?
This is the first I’ve seen of someone disassembling a MB manifold, maybe you guys can help me?
I have been chasing this for months, dating back to when I bought a MAF sensor because I got my check engine light with the code P170 (intake fuel trim something). I changed the MAF sensor, no luck!
I kept checking as recommended for a vacuum leak. I found this leak by running the car at idle and spraying MAS spray cleaner around the intake track, near the identified location, the spray effected the idle--bingo! I applied some extra torque to these bolts and the leak went away for about a month---but now it's back!
Needless to say I need to change this gasket, but I contacted my long time MB dealer and they said that the intake manifold is not “serviceable” here—in other words the intake manifold is sold as an assembly, so the gasket and torques specs are not available! They say I have to buy the entire intake manifold---big bucks!
In the photos in this thread it looks like this gasket is really an o-ring type seal right?
Help, has anyone come across this same problem on the 320 motor? How have you guys solved this? I can’t believe anyone that is mechanically inclined would buy an entire manifold to solve this leak.
Thanks for any help
Thanks for any help
#104
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Thanks for any help
Thanks for any help
#106
I had my manifold cleaned up by Anthony @ TVT Design.Check this thread - https://mbworld.org/forums/c36-amg-c...oject-c43.html and contact him for the proper sealant. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Would be nice to know what kind of sealant he used too since im i the middle of cleaning/polishing my intake mani...
#107
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/539x959/2014_12_14_20_41_08_77005a0f562d0104f89bf0d20032c16b5fec0e5f.jpg)
Hi, I'm new on the forum. I took apart my manifold and I'm not sure about applying gasket maker around the ports. Did you get any resolution to your problem? The yellow line indicates the original gasket that I'm reusing, the areas marked in blue is what I'm wondering about.
#108
Lower Manifold Channel Separation
May be a very outdated question, but how did you go about separating these from the external part? I accidentally broke the fork that moves the butterfly valves and I cant seem to get the internal chambers out of the lower part of the manifold to get to them..
I dont want to buy a new one but im not sure how to fix it at this point if I cant separate them..
Any help would be greatly appreciated!!
#109
Ignore the spots you have in blue, but you need to connect the parts in yellow as well. Essentially you should have a thin beat of RTV that runs straight down the manifold as well as on the outsides (which has a larger, thinker bead)
#110
Here goes nothing with a gravedig....original pics aren't showing up anymore...anyone got some pictures of the port work kicking around still? Sounds like I'm missing out on some beautiful intake ****!
#111
2002 CLK 55 AMG cabriolet Eurocharged
The 1998 to 2001 cougars are European designed and have the same intake concept.
The racing folks are gutting the secondary plates.
If you want to seal this intake properly use loctite RTV for Porsche and Mercedes Head gaskets. I have the number somewhere but it is intended for applications like this.
Recently modding my M113 and it was a necessity. Google head gasket sealants for Porsche Alusil engines. It is available on Amazon.
It is not recommended to gut the M113 intake secondaries without preparing for a re tune.
My 2 cents in this 2006 informative thread.
Cheers
Cheers
#112
i agree this is a huge problem for these forums lately, half the photos uploaded over the years are unavailable
#113
Cheers
Cheers
you mention the sealant but there’s very obviously some glue in some places inside the intake that need re - applied too
#115
https://www.amazon.com/dp/B015CC6WH0...v_ov_lig_dp_it
Here is a link to the sealant. I would apply to all mating surfaces of intake halves sparingly.
you dont want excess collecting into the butterfly.
Cheers
Cheers
