Pics of bad piston
They feel that this was a fluke. The engine did not go lean. No oil problems. Everything else looks fine. It was caused by a faulty piston, or possibly over-boost. My guess was that the piston had a weak spot and the boost did it in.
Good luck.
That is definately detonation there. I wish i had pics of my supra #4 piston to show you. Pretty simular to yours but the ringland was not cracked as bad as that.
Just remember that more boost causes more heat so if you plan on running it hard put a mix of higher octane with your 93 fuel for insurance.
They really do not feel that detonation was the problem.
Maybe take some better pics and pics of the top of the piston.
Sure on the slight chance it could have been a bad piston but that is very slim. You are the first that i know of to have had this problem from a kleeman SC 55.
You know it could have been some bad gas too.
seperated due to heat and detonation which became the foreign object that caused the piston damage. Very common is high boost Porsche turbo motors. I'm sure a good tech will check out the rods for straightness. You might want to do a gas sample to see what octane rating was in your beast when it blew. Just one more element of the puzzle to elimate. Good luck with your rebuild. FWIW,I don't think the JE pistons are the way to go in an AMG motor.
