G Force stainless brake line - Issues!!!! Leaking!!!!
G Force to resolve the issues. All 4 of my brake lines are failing. One has failed completely and is leaking. The remaining 3 are showing signs of leaking inside the protective outer sheething. I will post pictures soon.
If you have these brake lines be sure to check them and make sure they are not leaking or failing in any way.
Feel free to contact me with any questions.
Thanks Owen
Good customer service. Well done and thank you!
Owen
Owen
Owen
Sounds like a plan. Here are pictures of my lines. As you can see all are failing or have failed totally.Owen
The right front failed completly. It was leaking so badly I thought I had a master cyclinder going bad. It left puddles in the garage. That is the only one that failed totally.
The left front is just about to let go.
-O
I pulled the wheel off and have a leaking line as well. After I figure out what's wrong with the tire - I'm dropping off the CLK for fresh OEM brake lines at mbenzman's shop.
I guess I'll order you up a set too.
I wouldn't have believed it if I wasn't standing there. Now, I'm on the hunt for an 18 X 8 AMG Monoblck II!
The thing with SS lines though, (on motorcycles) they are supposed to be replaced every 2-3 years, just a safety measure, since there's no way to see how the actual line is doing, can't see the signs of wear, etc. On a car though of course it'll be harder to keep an eye on them until it's too late and they leak. I'm just wondering how old were the lines, or could be a bad batch...
I hope you guys get taken care of though, this could have been a nightmare if not detected soon enough
Called them and sent pics. Waiting to hear back.
