W208 Suspension Question
The 55 handles REALLY great right now. I would hate to trade suspensions and end up with decreased handling just for the look. Any suggestions for keeping the AMG spec performance and lowering the car significantly? Over an inch for sure...Especially if you have H&R's, is there a difference?
Also, does suspension changing void or hurt the extended warranty? Thanks!
Have you considered the euro-spec springs? They're designed for our cars and you won't have to change dampers...
They may be getting a little pricey with the exchange rate tho...
https://mbworld.org/forums/showthrea...ight=euro+spec
I am running 245 front and 275 rear on factory Monoblock IIs.
Rears will rub on big dips.
Just FYI.
First, your CLK is Black. Then I studied the tire sizes and SOMEONE had managed to STUFF 245s and 275s....I was like CRAY-ZEE mang!
The front is pretty low and I have alot more threads I could go down if I wanted to. Could probably sit the front bumper on the ground if it was all the way down.
