BMW 5w30 oil and 04 CLK55 AMG
Old Aug 20, 2008 | 06:54 PM
andy_c63's Avatar
2009 C63 AMG
Question BMW 5w30 oil and 04 CLK55 AMG
The technicians poured BMW 5w30 oil in my 04 CLK55 AMG. Is it going to be fine running on that oil?
Old Aug 20, 2008 | 07:07 PM
BelaMeca's Avatar
From: Los Angeles,Belgrade.Current Residence Zurich.
2017 Mercedes Benz E220D/GONE!JUNK!Current GLC Coupe 350d 4 Matic
ehhhh....what?
Old Aug 20, 2008 | 07:40 PM
andy_c63's Avatar
2009 C63 AMG
Originally Posted by BelaMeca
ehhhh....what?
Well... not MB technicians obviously. The techs from the company I am leasing the car with.
Old Aug 20, 2008 | 08:04 PM
Tony Yeung's Avatar
CLK 55 AMG
I think your good to go. BMW uses Mobil 1, just like Mercedes.
Old Aug 20, 2008 | 08:17 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Recommended oil for the 2004 CLK55 AMG is either 0W-40 or 5W-40, fully-synthetic. Doesn't matter if the oil is private labeled "BMW" "Audi" etc.
Old Aug 20, 2008 | 08:45 PM
andy_c63's Avatar
2009 C63 AMG
Thanks, guys. According to the brochure I just found, any 5w30 oil is not recommended for AMG.
https://mbworld.org/forums/attachmen...7&d=1197668134
However, I found this summary on a BMW forum. From what I understand, BMW 5w30 is similar to Mobil 1 0w-40.
http://forums.bimmerforums.com/forum...d.php?t=265292
What do you guys think?
Old Aug 20, 2008 | 09:14 PM
Pre-emptive's Avatar
Kleemann CLK 43K
The Northern America BMW oil is Castro 5W30 which does not comply with MB 229.XX. The M1 0W40 is Group IV which is much better than the Group III hydrocracked stuffs. I would change the oil ASAP.
Old Aug 20, 2008 | 09:36 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Change the oil ASAP. If you fill with 5W-40 or 0W-40 you are fine.
Old Aug 20, 2008 | 11:42 PM
andy_c63's Avatar
2009 C63 AMG
If I replace the oil with Mobil 1 0w40, will it mix with the remainder of BMW 5w30? Any potential consequences in this case?
Old Aug 21, 2008 | 12:17 AM
ohlord's Avatar
mobil 1 0w40 euro syn
mb spec ,no 30 wt. of any type is approved for use in the amg engine.BS on bmw 30 being the same as mobil 40.that is why they have uniform ratings and that is why you engine needs mb spec oil.
note the *
http://www.whnet.com/4x4/oil.html
fleece filter from autohausaz.com
diy oil change on mercedesshop.com resource section diy oil anf filter change #2.
topsider clone 2.5 gallon unit $25 at http://harborfreight.com/
probably one near you if you look up the store locator.
ohlord
Where do they find these quacks called mechanics?
Old Aug 21, 2008 | 08:03 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Personnally I like a heavier grade (0w40,15W50) but the 5W30 is not gonna hurt the car. I would run this oil for 3k miles and then chg to a heavier grade and also chg the filter. No sense waisting $$ and chging the oil right away again. I've used 5W30 Valvoline synthetic b4 but like I said I'd rather go heavier.
Old Aug 21, 2008 | 08:17 AM
Stiggs's Avatar
2003 CLK55
Next time tell the mechanic you drive a Benz not a BMW.
Old Aug 27, 2008 | 04:59 PM
andy_c63's Avatar
2009 C63 AMG
Thanks, guys! I changed the oil to Mobil 1 0w40 and fleece filter.
