what company makes good lowering springs for clk55 w209 and price?
i too have the same question.... also will the stock shocks hold or will they need to be replaced as well?
i'm gonna say the most popular choice of lowering springs are "H&R"...most of the folks around the board use them...i believe they run about $500 or so brand new...and i do believe they can be used with the stock shock setup...do a search for it, i'm sure u'll get some feedback...
Quote:
oooooh really...................? thanks for that bit of info.Originally Posted by chen38
u can get H&Rs from tirerack for 240+shipping.
I got H&R..
and I didnt had time to install the rear yet, but front looks good so far...
Quote:
yeah. and shipping was pretty fast. i think it is the cheapest u can find out there...Originally Posted by DBLNICKL
thank you for all for the info i was seraching and mostly it was the H&R springs that came up anyone have a pix of the car with them on?
ExploreFatTony001
close
- Join DateOct 2007
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveCLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Liked:22 Times in 19 Posts
If H&R are installed... will you lose the great stock comfort?
Front and rear H&Rs installed without any noticeable change in the ride. They will lower your car about 8-9 tenths of an inch which (IMHO) makes the car look a lot better. BTW, I'm still using OEM 17" AMG rims with the new Eagle F1 A/S all season tires.
Quote:
imho, you lose more comfort when you upgrade to larger rims and less tire profile..Originally Posted by FatTony001
lowering your vehicle 1.2" isnt gonna let you feel a great diffrence with the stock rim/tire setup.
inch will increase spring rate about 10% and if you keep oem rims the biggest difference with the drop will be the negative camber you will need to correct with a good hunter machine alignment at the dealer.
http://www.shox.com/appguide/shoxshop/
or tirerack
or tirerack
another thing im running 19's and if i lower the car will there b rub? and will i wear out my tires more? i know on my dsm i lowered it my tires are gone in like 6 months lol
if you just lower with springs you will be fine.
Just by the Brabus lowering springs, there not all that expensive and I run 19"
BelaMeca
close
H&R on 19's
Guys ! Im driving a CLK 2006 with 18 inch wheels. Now i just decided to go for H&R springs, But will i face probelms in the car ? I mean will i face problem in steering, suspention etc...
Will it effect the guarantee of the car?
Thanks Guys
Thanks Guys
Thanks Guys
Thanks Guys
