airbox removal, need help here
Old Oct 24, 2008 | 06:25 PM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
I must be blind or dumb... or both cause i've read every possible post on green filter install and that its basically easy , but I don't have a clue how to do it in my Clk55.
basically i've taken off the air hose tube thats connected to the front of the car, and i've removed the front engine cover part. (the part that has the mb logo on it) i know exactly where the filter goes in cause i can see it once i removed the air pipe. .... but how the heck do you remove those 8 screws that are installed underneath. i can barely put my finger on some of them never mind a torx driver.... or am i seeing this wrong.
does anyone have pics or a step by step.... because i'm stuck at trying to take out the screws.... if those are even the screws to take off.
Old Oct 24, 2008 | 06:37 PM
hhseouljah's Avatar
2001 CLK 55
you need to take off the engine cover part thats on the side close to the firewall. just pull on it like you did for the piece with the star. then you can work on the box to get the filters out.
Old Oct 24, 2008 | 08:21 PM
M-bENZ's Avatar
Corrolla
Check this out,
http://www.panchogun.com/FVWebPhotos...-MAF-5x100.jpg
Old Oct 26, 2008 | 09:04 AM
cindyclk's Avatar
Yes...those are the 8 screws. You need torx wrench to remove them. Home Depot and Lowes has them relatively cheap.
Old Oct 26, 2008 | 02:23 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
your airbox (that holds the filters) just *clips* onto the engine. You just grab the right and left side firmly and pull up (and kinda wiggle) and it will pop right off. Takes a little force, shouldn't be a problem.
Old Oct 26, 2008 | 08:46 PM
cindyclk's Avatar
Just re-read your post....sorry. Just pull the airbox off. It is held by 4 clips attached to 4 rubber bushings on the engine. Just pull. When you re-install, be sure to seat the round air intake into the MAF and secure the rear two clips before you do the front two.
Old Oct 27, 2008 | 09:17 AM
FatTony001's Avatar
Thx... I can see that all you guys have W208
I have the W209... Is it the same approch?
(Take the 2 airbox by the horns and pull up and wiggle; then when out, I use the Torx to free up the 2 filters)
Old Oct 27, 2008 | 07:41 PM
M-bENZ's Avatar
Corrolla
did u look at the website that I post above??? it should be the same process.....I used that to do my when I first got here.
Old Oct 27, 2008 | 11:51 PM
i'm pretty sure the w209 snaps onto the rubber knobs also. Key thing is when you're putting it back on, as cindyclk mentioned, make sure the MAF (air intlet to manifold) lines up properly before pressing it back on completely.
