KeyLess Go
Old Feb 3, 2009 | 03:01 AM
harmin5288's Avatar
2005 CLK 55 AMG
KeyLess Go
I haven't used the keyless go in long time and today I hit the start button on the shifter and nothing happened (Yes, I did have the key in my pocket). any ideas...is it something that I have to set on in the computer through the dash??
Old Feb 3, 2009 | 09:37 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
You may need to replace the battery in the key card.
Old Feb 3, 2009 | 09:49 AM
HCUBED's Avatar
W209 2003 CLK55 Coupe
This may sound dumb, but did you depress the brake pedal at the same time?
Old Feb 5, 2009 | 03:38 AM
harmin5288's Avatar
2005 CLK 55 AMG
yes I did press the brake pedal. thanks for asking...
Replace the battery in the "key card"...what is the key card?
Old Feb 5, 2009 | 08:18 AM
HCUBED's Avatar
It's the big black thing with the four push buttons and the tri star on it that you have been inserting into the dash mounted ignition switch to start the engine. Most probably call it an ignition key, or maybe a key fob.
It also contains a mechanical door lock key for emergency use, should the batteries die.
It has two CR 2025 lithium batteries that require periodic replacement.
When my batteries are low, the speedometer annunciator (information center) indicates the low key battery condition. It also reminds you to take the key with you when you get out.
I suggest you read the manual......lots of good information inside.
Old Feb 6, 2009 | 01:49 AM
harmin5288's Avatar
2005 CLK 55 AMG
the batteries are fine as the doors unlock and lock and the trunk opens just fine.
Old Feb 11, 2009 | 12:55 AM
cmorganjr's Avatar
2003 E320
Hey guys....it may not be the batteries. Mine sometimes does this and an awkward "jiggling" of the gear shift does the trick. There's a sensor or some kind of mechanism that has to be just right for the keyless go to work on my 2003 E320. Not often, but it does happen sometimes... Sort of like when some cars' steering wheels are locked too far to one side....you have to move it slightly to get the key to work (or to come out, etc)....
Old Feb 11, 2009 | 12:57 AM
jagass's Avatar
pick up
Replace the battery that you are using...
