2005 CLK Reliabilty score with problem spots noted
Old Jun 9, 2009 | 06:27 PM
JYO's Avatar
JYO
1999 E 320 (sold), 2015 AUdi S5 (sold) 2005 CLK55 Cab, 2016 Honda Pilot Elite, 2011 Jaguar XF
I meant to say 2003-2008 CLK reliability scores...........Have you guys seen this site?
http://consumerguideauto.howstuffwor...benz-clk-2.htm
And very importantly have any of you experienced firsthand or anecdotally any of the trouble spots they mention?
Old Jun 9, 2009 | 07:54 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
I have a Pre-certified Used 2004 CLK 55 AMG with Carfax and I have experienced '0' issues with all the mentioned issues listed in that article. The only problems that I've had has been a bad MAF sensor and Purge Valve...I bought a new MAF sensor for about $150 bucks (more than 50% cheaper than buying from the stealership) installed it myself...done. No issues ever since. However the purge valve has been replaced twice and it is still an issue as my CEL (Check Engine Light) continues to come...I took the car to my local MB shop who happens to be my personal mechanic and he can't fix it for chit. lol Maybe it's my mechanic but that seems to be the only headache that I've had with the car so far but I love driving it!
Old Jun 9, 2009 | 09:12 PM
ac_schnauzer's Avatar
I've had the following happen to mine:
"Transmission leak: Transmission fluid leaks from the electrical connector and may also travel through the wires to the electronic control unit requiring the connector and necessary O-rings be replaced. 2003)"
Old Jun 10, 2009 | 12:03 AM
JYO's Avatar
JYO
was it a big deal to fix? costs?
Old Jun 10, 2009 | 12:14 AM
MARTYMAR's Avatar
Any kind of transmission issues will cost you...especially on these AMG cars unless it's covered under warranty...
Old Jun 10, 2009 | 12:15 AM
MarcusF's Avatar
2002 CLK430
That site is a joke. A "clutch" is $915? In a CLK? LOL. And the CV joints are $4500? At a dealer, MSRP for a complete axle is $850. Times, two, makes labor about $1K per hour? Other than BlackBenzz, who else is breaking axles?
Old Jun 10, 2009 | 12:18 AM
MARTYMAR's Avatar
Old Jun 10, 2009 | 01:47 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
I liked the one about he iPod issue. Volume can be controlled via steering wheel, just not song selection, but it's not an issue
Old Jun 10, 2009 | 11:24 AM
AMG10's Avatar
Boy I'm glad I have a 2001 sounds like all they made after that was junk.
Old Jun 12, 2009 | 11:48 AM
wal's Avatar
wal
AMG-feet
knocking on wood ... none of these happened to me so far ... the only problem i had was the R headlight needed to be replaced (the module not the bulb) and was covered under warranty.
Old Jun 12, 2009 | 12:15 PM
jagass's Avatar
pick up
Thanks for sharing the link...
Old Jun 15, 2009 | 06:37 PM
fourml8r's Avatar
2005 CLK55 AMG CABRIOLET
i had the same problem, fixed under warranty at no charge.
no i'm starting to have "Electrical issues", which may all be related:
1. SRS malfunction is lit on dash
2. Passenger seatbelt arm does not move at all
3. Driver seat headrest won't move
4. Driver seat won't release using latch to access rear seat
i have another issue which the dealer has tried to fix several times but without success.....when making a left turn something is rubbing in the passenger front wheel area causing a speed sensitive ticking noise.
Old Jun 15, 2009 | 10:44 PM
JYO's Avatar
JYO
Fourml8r, when did you start having these problems? My used 05 cab just came in today and I'm wondering of extended warranty is needed.
