Need opinion on N/A 550HP CLK55
Old Jan 29, 2002 | 12:41 AM
EVO///AMG's Avatar
Car has 7K, built by respectable tuner. Engine upgrades include, high-compression pistons (12:1), titanium rods, reinforced crank, on-board ECU to control air/fuel, headwork w/ injectors, high-flow exhaust system (cat-back) in addition to chassis stiffening modifications. Claimed power output is 550+HP/490+ft.-lbs. I have a CLK55 right now and can only imagine how this car must drive. Am seriously considering selling my car and getting this. Any idea what a good price would be for it though? Not sure what they want for it...heard this from a car broker who didn't give me any price figures.
Old Jan 29, 2002 | 12:53 AM
Mach430's Avatar
A Kleemann supercharger would provide more torque, and you would be able to rest assured that the quality is top notch. I'm almost positive that it would be cheaper to add it to your car then it would be to buy the one with the engine mods.
Old Jan 29, 2002 | 01:01 AM
Sleestack's Avatar
If I were you I would take your existing 55, send it down to Oberklasse to have an MKB 55 Hypertune Kit, MKB 3.07 Differential Software and Vmax Removal Software installed, then send it over to Evosport to have a Kleeman SC and upgraded suspension and brake components installed. You'll end up with a SC engine that breathes better and sounds like a beast. I'm not sure about the cost wof selling your existing CLK and buyiing the other, however, if costs are similar you'll end up with a faster, meaner Mercedes from hell.
Old Jan 29, 2002 | 01:14 AM
Mach430's Avatar
Actually, we (Evosport) can do the MKB work as well. If you're interested in the MKB or the Kleemann kit (or anything for that matter), feel free to email me at ben@evosport.com; I'd be happy to help.
Old Jan 29, 2002 | 12:54 PM
Sleestack's Avatar
Mach, I know you guys do the MKB diffeerential software, however, I'm not sure you do the MKB 55 Hypertune.
Old Jan 29, 2002 | 01:53 PM
JamE55's Avatar
Out Of Control!
Can you imagine how much power that'll be with the MKB Hypertune 55 + Kleemann S/C =
Old Jan 29, 2002 | 01:57 PM
bodyart27's Avatar
CLK55
compression
I would not attempt to put a supercharger on a car that already has high compression....
by the way - who is the tuner???
Old Jan 29, 2002 | 02:06 PM
Sleestack's Avatar
The MKB Hypertune Kit does not affect the compression ratio.
Old Jan 29, 2002 | 02:38 PM
Mach430's Avatar
Re: compression
Kleemann superchargers do not need to change the compression ratio of the engine. This is because of their well designed intercooler, which keeps the engine from being overstressed. On the other hand, the AMG superchargers do reduce the compression ratio to prevent their supercharger from causing engine damage. There are some very helpful posts on this topic in the Performance, Upgrades and Tuning forum
Old Jan 29, 2002 | 04:11 PM
bodyart27's Avatar
CLK55
compression
I could see doing a supercharger on a stock 55 - but the one mentioned above running 12:1 was the one I was speaking about - I would *think* even with the forged crank / not maxing out injectors / MAF etc. you would expect trouble
just my thoughts
Old Jan 29, 2002 | 04:51 PM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Kompressor on 12:1 CR engine
An engine with 12:1 CR is nearly impossible to supercharge with street gasoline, no matter what type of Kompressor or intercooler.
There is no possible way I could recommend an KLEEAMNN supercharger for an engine with this high a CR.
Old Jan 29, 2002 | 09:03 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
There is an interesting article on conversions re KLEEMANN C32K AND CLK43K mods in last month's "Car & Driver."
Speed gains are only 1/10 of a second from 0-60 mph. NEGLIGIBLE!
The CLK43K has 427 HP and the CLK55 AMG has 349 HP.
http://www.caranddriver.com/xp/Caran...emanc3243k.xml
Old Jan 29, 2002 | 09:49 PM
Sleestack's Avatar
Sleestack
I think what you are trying to say is that the speed difference between the SC CLK430 and Stock CLK55, despite the significant difference in HP, is only .1 seconds, which you consider negligible. The difference between a non SC CLK430 and a SC CLK430 is obviously not negligible. I've never seen a dyno on a Kleeman SC car, so I'm not certain that a SC CLK430 puts out 430hp, however, one thing to consider is that the Kleeman had 19" wheels. I'm not sure about the wheel weight of those rims, however additional wheel weight and the increase in diameter would adversely affect the 0-60 time.
Old Jan 29, 2002 | 09:53 PM
Mach430's Avatar
That's the 0-60, .2 seconds for the qtr mile. But taking a 430 with a stock 6.1 0-60 and turning it into a 4.9 is a great accomplishment. And that's without changing the differential. I'm not sure how much you've followed the Kleemann topics, but the 55 produces 550HP! If I had that much HP, I'd be to busy driving to ever post here again (if anyone wants me off the boards, please feel free to make this dream a reality!).
Sleestack's Avatar
The other thing to consider is that a CLK55 was not tested against the SC CLK430 on that day. A number of factors can affect performance numbers on any given day. It is completely possible that a CLK55 on the same track, driven by the same driver, would net results of 5.2 sec or worse, as is the case in some perfromance numbers reported on the 55.
Old Jan 29, 2002 | 10:16 PM
Mach430's Avatar
Actually, we carry all MKB products including the MKB 55 Hypertune kit.
Old Jan 29, 2002 | 11:06 PM
karl k's Avatar
I was referring to the recent Car & Driver article, which states that the CLK43K (Kleeman) has 427 HP and the CLK55 AMG has 349 HP.
Speed gains are only 1/10 of a second from 0-60 mph (CLK43K has 427 HP - 78 more HP - over the standard CLK55 AMG with 349 HP.) That 1/10 of a second gain from 0-60 mph is NEGLIGIBLE according to subject article.
NOW, according to MB's official site, their is ZERO gain, because the 2002 CLK 55 is rated by MB at 4.9 seconds 0-60 mph.
This is identical to the CLK43K!
Old Jan 29, 2002 | 11:30 PM
renncpe's Avatar
w203 c230K 2002
Re: Sleestack
Larger diameter tires, I'm sure that they would be with in 10 - 20 rotations a mile. I would expect better times with a 75 hp differential.
Randy
Old Jan 29, 2002 | 11:42 PM
Mach430's Avatar
Read his earlier post... In order to get a true comparison to the 55 is to test the 55 under the same exact conditions. Also, it is difficult to get 430HP to the wheels without the ESP taking over. I have seen the 430K as well as the 55K in person. They are both incredibly powerful machines. I think the best way for you to understand this Karl is to supercharge your 55. 550HP has to at least tempt you a little bit!
Old Jan 30, 2002 | 12:00 AM
TripleCap's Avatar
2002 MB CLK55
Does anybody have a ballpark figure on what supercharging a stock 55 would cost all in? Email me if that is better. Thanks.
Old Jan 30, 2002 | 12:14 AM
karl k's Avatar
Ben - I had the 2001 Vette a year ago. Enjoyed it for 6,000 miles.
The new 2002 Vette Z06 with 415 HP (20 HP more over 2001) runs 0-60 MPH in 3.9 seconds.
For $50,000 that's the best deal - if you like that much power/speed.
I just enjoy the 2002 CLK55 design, bells and whistles; the power/speed is just fine and manageable for me: 0-60 mph 4.9 seconds. It's a perfect match.
...just wish the markets would turn ^ ...fast.
Old Jan 30, 2002 | 12:18 AM
Mach430's Avatar
I know.. The 55 is definitely a great car, and it will most likely last you longer than the corvette ever could.
Old Jan 30, 2002 | 12:20 AM
awiner's Avatar
2003 CL55 AMG
On a 5.5 enigne you are looking at approx $17000 + install (usually around $1500.00)
Old Jan 30, 2002 | 03:07 AM
Sleestack's Avatar
Although the article does post those times, it doesn't say anywhere that it considers those speed gains negligible. It talks about the CK43 being indistinguishable from stock in terms of engine noise and tractability, however, I don't see the article describing the improvement in 0-60 times or the overall power and performance gains as being negligible compared to a 55.
Old Jan 30, 2002 | 03:19 AM
dj-po's Avatar
KLEEMANN C230K
If you guys want to know why the difference in 0-60 times in relation to HP just talk to Brandon at Kleemann. Just ask him how long the tire marks were on the CLK43K. I saw the pics, were nearly 100 FEET LONG!!!
