Brakes
CLK55 '05 CLK320 '02
Brakes
How often do you guys change your brakes?
I changed my brakes back in march 2008 and 30,000 miles later my front breaks are squeaking so bad. The dealership gave me a quote of 1800 + tax for new front rotors, pads, and sensors.
Should I just go ahead with that or would an upgrade on my brakes be a better idea?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
wow, i think you can get front rotors/pads/sensors for less than $500 in parts (best to check parts.com or a similar website for OEM parts) and approx 2 hours of labor. If you know what you're doing, you can replace the pads in under one hour for both sides and the rotors/sensors only take a maximum of 5 minutes each.
Brakes are purely driver specific. I can go 50K, or I can go a couple of track days. It all depends on how I drive.
The rotors are the most expensive parts and they should be mic’d. That’s when someone takes a micrometer and measures the rotor thickness.
Rotors have a "minimum thickness while servicing" spec. If they are above that, slap in a new set of pads and sensors, and you're done. Many rotors last two sets of pads (mine included).
Brake spec for a W208 are here. The next time I have the WIS open and remember, I'll add the W209 spec as well.
![](http://www.marcusfitzhugh.com/CLK/DIY/photos/misc/brake-mic.jpg)
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
item #?
were they 2 piece full floaters drilled and slotted?
did you get them installed and if so what kind of pads did you go with?
02 CLK 55 AMG,09 C63 loaded with P30
I highly recommend Hawk perf ceramic pads. Hardly any dust and so far put almost 20k miles on front pads. Still have about 80% pad left. Too bad they dont make them for the C63.
