THE blower thread
Rating: Thread Rating: 25 votes, 5.00 average.
Old Feb 28, 2012 | 01:41 PM
  #676
betrezra's Avatar
C63 507 AMG DA Car #19
Ahmed my car is clearly using the mass air signal voltage with rhestat (res box).
My car shifts the same no matter the rheostat settings.
Perhaps a diff between w208 and w209 klee setups?
Old Feb 28, 2012 | 01:42 PM
  #677
betrezra's Avatar
From what I understand Jerry tunes through MW..... and I will not go there.
I'll do some research and see who else he works through in H-town.
Once bitten twice shy.
Old Feb 28, 2012 | 02:26 PM
  #678
OverDrive's Avatar
Volvo
Slightly offtopic, But what Spark Plugs are you guys using with your Kleeman S/C's, Time to change mine, so i'm wondering what I should get. I think I have the Bosch fr5dc+ Copper.
Old Feb 28, 2012 | 03:59 PM
  #679
betrezra's Avatar
Somewhere back in this thread the spark plugs are listed.
I changed mine after 5K miles and new plugs made a HUGE Difference.
Old Feb 28, 2012 | 04:01 PM
  #680
ahmed18881's Avatar
frankenstein 2001 CLK 430
well i got a copy of the kleemann instructions basic setup (instal manual was available on vivid racing) the one with no tune, and i found out i needed a tune because i have bigger injectors (e55k ones) and that i needed to lessen the timing because i wanted to run 0.8 bar of boost, the reason why i believe i can run 0.8 bar is that i have the 500 engine which has a compression 10:1 unlike the 55 NA engine that has either 10.5:1 or 11:1 compression ...
i have tried to clamp the voltage of the MASS signal to 4.85 before using a simple voltage clamp, but when the ECU sees a constant voltage it will freak out.
without Jerry's constant support i was not able to complete this project, he worked so much to make a base line tune that made the car operate safely and we started to fine tune it to what it is now.
Old Feb 28, 2012 | 04:35 PM
  #681
blackbenzz's Avatar
haters crazy
Originally Posted by hami
btw I know I've asked this before but since most the guys subscribed have the kleemann blowers can you guys confirm that you have a resistor wired to your MAF? I know blackbenz has one I just wanted to see if I am the only one missing that. I had jerry tune my TCU but it didnt solve my shifting problem. blackbenz has been helping me out with this for sometime and we'r both sure that it might be the reason for my shifting problem
I'm hoping its the maf voltage. It should be
Originally Posted by ahmed18881
i don't have a kleemann but i had to put the resistor to fix my AFRs, nothing to do with the shifting thou
The cars shifting s based off the MAF reading from what I understand.
BB -
11.8 up top is OK.... but I didn't comment on the part throttle afr's and fuel trims which are lean.... my ltft's were steady going up to 1.18 plus.
Plus I'm a bit paranoid at burning a piston, or worse damaging the block. I'm on a tight leash with mods this season due to some other endeavors I've
takenup..... vintage guitars/amp addiction has set in. Picked up a 1955 fender champ tweed all orig.... and last week found a nice 1959 fender bassman tweed....
THE guitar sound of the gods..... (I digress).
Oh ok gotcha. I don't know anything about guitars but sounds cool
Jerry can do magic, he mail tuned my car (no dyno just road logging)
Yes he is a magician lol
from my research, i believe the shifting problem occurs from the air mass signal the one that monitors the air, kleemann uses the temperature signal to trick the car that its colder and dump more fuel.
when you go over 4.85 volts hard shifts will occur which could make serious damage, can't comment on these because as i have the blue tops solenoids which make the car really shift good (harsh shifts). My friend is running the NA 600 solenoids they are better than the stock but not as crisp as mine
The MAF voltage is adjusted. The MAF houses the IAT sensor as well but I believe the resistor does not effect the IAT readings.
What's MW? I'm guessing a shop you've had bad experience with. Jerry is a good tuner based on my experience
I was using NGK BCP7ES with good results before switching to E55 ported heads. They are copper plugs so they are cheap
Old Feb 28, 2012 | 07:43 PM
  #682
blackbenzz's Avatar
haters crazy
The maf voltage definitely effects shifting. I'm messing with mine and can see big changes even when i'm not at wot. And wow does it have an effect on the cars performance! I'm getting sick of messing with it though. Driving me crazy. I'm just going to dial in as much resistance as I can and work my way backwards. Maybe I will do it this weekend at the track
Old Feb 28, 2012 | 07:52 PM
  #683
betrezra's Avatar
BB - I reset my trans adapation this weekend AND WOW!!!! What a diff.
I'm sure an old pro like you is aware of this.
It's night and day..... makes the car respond more like my wifes old pp c63 car.
Amazing how the adaptations get all out of whack over a year of stop-n-go daily driving.
Old Feb 29, 2012 | 02:42 AM
  #684
ahmed18881's Avatar
aha, so what i get from your experience we have to find the best voltage to let the car shift strong and fast?
Old Feb 29, 2012 | 03:25 AM
  #685
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
It is amazing how different the car feels after the reset isnt it? After just a week of stop and go it'll be back to slush box mode.
Old Feb 29, 2012 | 05:54 AM
  #686
betrezra's Avatar
Kev - yes.... I was skeptical...... but it really works.
Old Feb 29, 2012 | 08:48 AM
  #687
ecampbell's Avatar
2008 BS
Cool
LOL, this is the post of the day. 27 pages (edit 28 pages) and you are worried about something going off topic???????
Old Feb 29, 2012 | 09:35 AM
  #688
betrezra's Avatar
It's ALL blown benz related. So I endorse this post
Keep it coming.
Old Feb 29, 2012 | 11:57 AM
  #689
OverDrive's Avatar
Volvo
Haha, Ok, Ya yall were talking about MAP Sensors so didn't want to interrupt the deep train of thought on that..... I have searched the CLK55/63 forums and still haven't turned up really anything for spark plugs. I know what we use for stock, but since most of us on this thread are under boost, im wondering what everyone is using.
Old Feb 29, 2012 | 04:50 PM
  #690
betrezra's Avatar
BB rec these: NGK BCP7ES
I'm using the Champion's rec by PTE a few pages back. Too lazy to search.. But you can search this thread (using search feature) for spark plugs..... or champion. The champions are very cheap and readily avail at most auto parts stores.
Based on the cond of my 1st set of plugs @ 5K miles... I'll be changing mine very oil change as a normal main item.
Old Mar 1, 2012 | 08:49 AM
  #691
Kevwood's Avatar
?..Based on the cond of my 1st set of plugs @ 5K miles... I'll be changing mine very oil change as a normal main item.
Kleemann actually recommends that according to their service plate supplied with the s/c kit. I'm going to pop one of mine out at the next service interval and have a look especially after hearing how fouled up yours were (and yeah, I remember you had some mega MW issues but still).
Old Mar 1, 2012 | 11:53 AM
  #692
betrezra's Avatar
I would not have them work on my weedwacker. (i digress)
Def pull the plugs and check. My car really woke up after fresh set of plugs.
Old Mar 1, 2012 | 12:47 PM
  #693
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
I have a uber noob/bench racing question.
I am not one to makes custom changes/tinker. Just bolt on and go.
With my current mods, except for CF airbox of course, what kind of gains would I be looking at by adding the Kleeman supercharger with their tune. Nothing custom on the kit, just run it the way it was sent.
Old Mar 1, 2012 | 01:29 PM
  #694
betrezra's Avatar
From my research following a few builds on here.... most kleemann cars running the kit provided boost/fuel.... with just headers and blower and stock pulley are 380-410RWHP dep on the dyno and conditions.
Cams add a bit more
P/P heads at a bit more
smaller pulley / tune adds more
My car dyno'd @ 471rwhp / 481rwtq with blower, klee headers, p/p heads, sm pulley, klee tune.
Old Mar 1, 2012 | 02:50 PM
  #695
Nachtsturm's Avatar
Cams add a bit more
Hmmm.
With the provided kit, do you think I can gain 10mph in the 1/4? So traps around 118-119mph?
Cannot wait til your car hits the 1320 lol.
Old Mar 1, 2012 | 05:56 PM
  #696
hami's Avatar
CLK55 '05 CLK320 '02
Originally Posted by Nachtsturm
Hmmm.
I was able to trap 117 with bad shifting so yes I could say 120 should be possible
Old Mar 1, 2012 | 07:08 PM
  #697
betrezra's Avatar
Try youtubing search on BB kleemann clk55... his CAR is FFFFASST in the quarter!
Hami - that is impressive my friend.
I'll hit the track in some 70 deg weather, and probably throw a splash of high test in the tank for sec blanket.
Just did the DIY power steering fluid flush and install new power steering reservoir and new gasket. Super easy work that goes like this (for me):
* drain fluid from reservoir, I started using a simple brake bleeder vac kit, but that was too slow, so then hooked up the marine engine oil changer unit.... which sucks at an unbelievable rate. Sucked the res dry.
* pull the line from the res to the low pressure side (cooler in bumper), and hooked my oil changer sucker to the low pressure side (inlet to the res) and pulled vac on the system and drained the funky dark fluid from the system.... with only 36K miles it was nasty.
* Installed new gasket, and new reservoir, re-installed the low pressure line with new worm gear clamps. Then fill res with new mb fluid, start car.... and add fluid until proper level. Power steering pump "sounds happy"... either placebo effect.... or NEW fluid ... I choose the later.
Cheers Gents. Oh and no more leaking.
Old Mar 1, 2012 | 10:37 PM
  #698
hami's Avatar
Wish I asked u guys about this back in december I had he dealer check it out and do the work for me
Old Mar 2, 2012 | 03:14 AM
  #699
Kevwood's Avatar
Are you running the OEM TCU flash?
Old Mar 2, 2012 | 10:37 AM
  #700
Nachtsturm's Avatar
Not bad. You are cammed though correct?
Did you ever run it N/A?
I would not cam it, just supercharger and that's it. Just contemplating on investing in this platform or waiting for the next platform to come down in price.
120mph traps would be perfect.
You have already rated this thread Rating: Thread Rating: 25 votes, 5.00 average.
