THE blower thread
#901
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
#902
I was really disappointed to realize the high compression on the N/A 5.5L will prevent me from upping the boost any. I mean, the car is damn quick, but I was expecting more and there isn't really anything else to do outside of swapping in either an E55 engine or going into the bottom end with E55 parts to lower the compression.
I just jimmy rigged a boost gauge to see what I was getting and I'm seeing 5psi with standard pulley and Kleemann headers.
#904
C63 507 AMG DA Car #19
11/6/12 Update -
Stopped by the body shop tonight and things are progressing nicely.
**Satin Silver Paint.
**Gloss black roof.
**Having my slk55 wheels painted gloss black with the lips polished (ala 2013 c63 style).
**All CF bits sanded and recleared (total copy of the kevwood method)
Should be done next week.
** THen install DTM wheel.... and NJOY>
**Gloss black roof.
#905
![](http://i186.photobucket.com/albums/x88/betrezra/mattesilver.jpg)
Big thanks to JC autobody in Houston, TX.
Nero had his wheels done there as well and I think he's pretty happy with them
713-433-6250
#910
CLK55 '05 CLK320 '02
Nice man looks great thanks for the pics. I'm considering the steering wheel but I might see if I have enough left to get one ordered. Still have a list of things to add and prioritizing isn't something I'm good at :p
#911
A little update on my attempt at running my DAS Xentry to clear an SRS error from when the body shop pulled a door panel and started the car.
My DAS laptop T30 Bios-memory died....... OK so no big deal replace bios battery.. NOPE.....old school IBM T30 bios has a password which I don't have...... search interweb and find a way to attempt to hack the bios chip...... so build little simple circuit with res and diodes and RS232 port....... tricky part you have to solder two wires onto the circuit board of the bios chip on the T30 laptop...... then hook this up to you 2nd laptop and run some interrogation software to read the bios chip... then you process the output with a decoder and BAM..... in theory you get the password for the T30 so you can run DAS Star..... I got as far as soldering the wires to the bios chip... and chip would not read....
fast forward...... 7 hrs later...... shop ebay... found another T30 for $130 shipped..... throw old T30 in garbage, enjoy a brew and track shipment..... I'll be running DAS this weekend.
Bottom-line don't let your Bios battery die on your DAS Star T30 machines.... you'll get a lock-out condition which may render your machine useless.. fortunately they are cheap used.
#913
Blown 208 55 amg, 211 55 amg
Announcement for HPS Supercharger Guys, HPS is closing its doors forever at the end of the year and I have stocked up on some misc replacement items if anyone needs anything!
#914
Replacement T30 Thinkpad arrived! DAS STAR hooked-up... cleared the stored Airbag in side door panel error....... SRS light GONE! Thanks DAS STAR!
Time to enjoy my wheels.
Also bonus... LTFT's..... near 1.00000 MAS is happy.
#916
Bonita - whats the problem with your STAR? I did get my 1st HDD w/DAS STAR on it that did not last very long.... these cheap knock-offs come at a reliability risk it seems. My 2nd one is working fine now with the new laptop.
#918
Jeff - I haven't been around for quite a whole but wanted to say that the car looks awesome with the new paint! Make sure to link us to your new thread before this one gets locked up.
#919
Good to see you back Kev.
I want to lock this one up with all the extra garbage from the start of the build nd then just put up a new short summary of the build/ mods.
This car is pretty much yours in matte silver minus some of your custom touches.
#924
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Spare tire wheel house
It is Plastic . I did a change out to a center mounted piece . And Did a DIY with pictures. years ago It still should be there , and with Part numbers
Cheers _PTEngineering
