THE blower thread
#101
1 more thing if u have the $$$ but its a risk.
compression ratio:
easy way, if there are thicker headgaskets already available or have custom ones made. lower compression.......increase boost
hard way, swap in piston/rod assy's from an e55 amg. it will take you from 10.5:1 to 9.0:1
edit: common mistake peeps make with boost is compression bc the power increase with added boost isn't linear
for example:
engine 1 10.5:1 engine boosted 7lbs 510hp maxed out
engine 2 8.5 engine boosted 12 lbs 762hp maxed out
same engine minus compression
meaning the power increase doesn't correspond with the numbers. only X factors is engine efficiency and HEAT!!! and of course detonation but any competent tuner should be able to deal with that.
compression ratio:
for example:
#103
C63 507 AMG DA Car #19
Motorwerks is tracking down the 82mm TB for this build.
If anyone in the know has the low-down on where to source, and the blower mods (porting) please help out.
I'm prob adding this to the mix.
Also chime in with anything I'm missing mod wise for the motor.
#104
What do you need to know? I can help.
#107
Came across this kleemann blower kit for a clk550........
http://www.importdynamics.com/catalo...9-p-56114.html
#110
2.11.11 Update
Just got a call from MW - kleemann headers are just about done getting installed..... (swapping out the shorties to mid length K)..... then back on the dyno. Then to paint, then to me.
I forgot what it's like to drive a clk, but I think the wait will worth it.
#112
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I love the Kleemann TCU flash. It made my shifts so much tighter and faster. I think they will discount it to $695 and it's worth it.
Going on 3mo's in the shop.... but it's partially myfault as we keep adding mods......
Is there anything else I'm misssing:
Kleemann Eaton Blower
Smaller pulley
Kleemann midlength headers/downpipes
300cell 2ndary cats
PTE Cams
Ti Retainers
Port/Polish Heads
180 thermostat
Tune
LSD
I'm thinking the next thing to do will be trans: clutch packs/refresh, tq converter.
Blackbenz - any thing missing in the mix? I know you have that "secret sauce" from up east
Smaller pulley
300cell 2ndary cats
PTE Cams
Ti Retainers
Port/Polish Heads
180 thermostat
Tune
LSD
#115
I didn't drive the clk55 for a while and decided to take it for a drive the other day. Man I LOVE that car! You will be very happy with it. Coming from driving ML500 for a while it will blow your mind! Enjoy it!!!
#116
CLK55 '05 CLK320 '02
#117
#119
I doubt I can come over this friday but i'll keep u posted when I can
#121
'05 CLK55, '04 CLK320
lets make that change and bring some down south. Im not too far from you, lets meet at no problem raceway one day
Uploaded with ImageShack.us
#124
OK more updates..... 1st custom pulley was machined wrong did not fit the blower shaft..... so back to the machine shop ..... supposed to be @ MW Friday... then dyno-tune, then paint.... then to me.... I know I sound like a broken record.... I keep reminding myself this will be FUN when it's done LLLLLLLLLL
