Broken Engine mounts and Transmission mounts
Old Aug 22, 2010 | 07:30 PM
JSDCLK63's Avatar
2007 CLK63 Cab
Has anyone else broken their engine mounts and transmission mounts? My CLK 63 Cab only has 21k miles, and just a few days ago it broke down. Anything else I should be concerned about?
Old Aug 22, 2010 | 11:29 PM
MarcusF's Avatar
2002 CLK430
Engine mounts are normal wear parts. The transmission mount, which is inexpensive on a W208 - I don't know what they cost for a 209, suffers accelerated wear if the engine mount breaks and isn't attended to promptly. For mount longevity, mileage isn't so much an issue as how much torque they have to handle (tire grip and throttle possition) and how often. I hope it's an inexpensive repair.
Old Aug 23, 2010 | 03:42 PM
Johnpidge's Avatar
W208 CLK55
Yes - tranny and engine mounts just changed
Old Aug 23, 2010 | 11:27 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
I had my motor mounts replaced and completely agree with MarcusF, they are a normal wear and tear part on Mercedes.
Old Sep 17, 2010 | 02:38 PM
Greenzilla's Avatar
2007 AMG CLK63
Yep - 22k on mine and just had them replaced - luckily MB considers them a warranty item and the job was free so I did not get to see what the normal price would have been. End result though was a much smoother feel at idle and it actually seems to handle better - not sure why, maybe when they float on the hydraulic fluid of the mount, they do not impact the suspension since they no longer are banging on the frame when the motor twists.
Old Aug 11, 2011 | 04:47 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Kleemann mods on my 23K mile 04 CLK = new mm's today!
Getting the better W113 E55 mm's (all 3).
Old Sep 3, 2011 | 05:15 PM
goatfarmer1970's Avatar
C63 Coupe 507, CLK55 Convertible, X1 35i, 70 GTO convertible, motorcycles
Anybody have experience with firmer mounts? I have a C63 and am looking to buy a CLK 55 or 63 cab, and really feel like firmer motor mounts would be better. Like does the CLK 63 BS use firmer mounts that could be a direct replacement for the cabs? Thanks.
Old Sep 3, 2011 | 09:39 PM
Stiggs's Avatar
2003 CLK55
Is there an easy way to tell if you need new motor mounts? What should I be looking for?
Old Sep 4, 2011 | 08:43 AM
betrezra's Avatar
On my 04 clk55 kleemanized car:
* squeaky dash noise mainly under braking....
* non-solid feeling from front frame rail area... hard to describe easy to feel.
* look for oil fluid around mm's
* not sure if this applies to benz... but the old fashioned method.... jack up motor with pc of wood with slight pressure... if motor mounts have gap then they're bad..... or power brake car with hood open.... 2nd person look for rocking motor.
Old Sep 4, 2011 | 10:03 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Are the E55 MM's made of a different material? I just bought a new set of 209 MM to be installed when my car goes in for the Kleemann stuff.
Old Sep 5, 2011 | 04:31 PM
betrezra's Avatar
According to Klee USA the E55K mm's are diff durometer rubber to handle the extra hp/tq of the blown 5.5 motor. So I have my dealer install those MM's.
GL
Old Sep 6, 2011 | 02:36 AM
Kevwood's Avatar
Thanks, I'll see if I can return mine and get a set of the E55's.
Cheers.
Old Sep 6, 2011 | 03:40 AM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I had engine mounts just replaced on my ML63 after 28000kms. Symptom was squeaking noise that you might have blamed on suspension
