my s/c "kit" is coming couple q's
Old Mar 15, 2011 | 04:20 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
Originally Posted by dohcfiend
unless i can score a timing cover/case cheap this swap is doa.
actually u don't need the whole timing cover, u need an amg fabricated piece to hold one of the pulleys for it only, i didn't change mine ... although i think its better to change it to the 55k one because it already has routing to the engine oil cooler (us-spec 500's and 430's don't)
Old Mar 28, 2011 | 04:50 PM
dohcfiend's Avatar
2001 CLK 55 AMG.......... 2001 Corvette Z06.........
don't know if it helps on the oil cooler routing but i have a us spec clk 55. Can this piece you are referring to be ordered? Can the guy that made yours make another for me?
Old Apr 2, 2011 | 04:54 AM
ahmed18881's Avatar
yes i can be ordered but from germany, thats where i ordered mine, will look up the part number and send it to u
Old Apr 7, 2011 | 04:40 PM
dohcfiend's Avatar
you are the man! i just received a partial shipment today consisting of the cams, valve covers and s/c assy.good gawd is that thing heavy!!!!!!
Pending are the pullies, waterpump and airbox assy's
Also is there a way i can contact you directly? can u pm it to me? next would you recommend i use the e55 cams or stick to the clk55 cams since i have the 10.5 pistons. thinking of valve to piston interference issues with lift if the 9:1 pistons used valve releifs(inverted dome)
Old Apr 7, 2011 | 04:41 PM
dohcfiend's Avatar
i would imagine the clk 55 cams would be more aggressive since they are n/a cams.
Old Apr 7, 2011 | 04:42 PM
dohcfiend's Avatar
almost forgot....the e55 cyl head assy's. which if rumors are correct are more efficient than the clk 55 heads on the exhaust ports plus the necessary valvesprings i need.
Old Apr 7, 2011 | 04:44 PM
  #32
dohcfiend's Avatar
too bad it isn't a dohc engine. i would use n/a intake cams and s/c exhaust cams.
Old May 12, 2011 | 10:41 PM
  #33
dohcfiend's Avatar
NVM I WAS SCAMMED by jpohl402.......im out of the $$$ and don't feel like buying again for some time.
Old May 14, 2011 | 09:37 AM
  #34
carpecervisi's Avatar
CLK55 Conv
Sorry to hear that! What happened?
