Tune up list?
Old Nov 1, 2011 | 12:03 PM
400HP55's Avatar
2001 CLK55 AMG
I think i will just go with the OEM mounts for the W208 like you did. I mean they should last at least another 60k miles.
Heres my 100k list. Im picking it off slowly...
Valve Cover Gasket (Left/Right) - Ordered
Service A - Waiting to do this until all of it has been done
Transmission flush + filter and plug change - Waiting on this until 95k miles
Differential fluis change - 95k miles
Brake Fluid Flush - Done
Cabin Filter - Ordered
Air Filters - Done
Collant System flush - 95k Miles
Thermostat - Ordered
Serp Belt - Done
Idler Pulley - Check Ok
Spark Plugs - Done
Cylinder 6 Wire - Ordered
Coil Pack 6 - Ordered
Fuel Filter - Done
Motor/Trans Mounts - Ordered
Exhaust Rubber Hangers - Check Ok
Crank/Camshaft Sensors - Check Ok
Power Steering Flush - 95k Miles
Diff side Seals - Stil need to be inspected
Drag Link - 100k Miles
Front Lower control Arm Bushing - Needs Replacement
Front wheel Bushing - Needs inspection
Am I missing anything else or does this cover most everthing???
Old Nov 1, 2011 | 02:43 PM
MarcusF's Avatar
2002 CLK430
Now that you've made up your mind, let me throw a wrench in
Pancho just installed 209 mounts in his CLK430 - https://mbworld.org/forums/clk-class...or-mounts.html
Old Nov 2, 2011 | 12:03 PM
slowsky's Avatar
2011 C63
my mech installed the w209 mounts to see if it would help with my idling issues...i think it maybe stiffer but could just placebo effect...it fits perfectly fine..my mechanic was suprised actually that it was a direct fit...
Old Nov 3, 2011 | 04:14 PM
400HP55's Avatar
2001 CLK55 AMG
What do you guys think about Beck Arnley parts? Cause i have 2 option for these mounts. OEM (Lemfoerder) $80 each for the W209 or Beck Arnley for $52 each.
Old Nov 3, 2011 | 08:14 PM
400HP55's Avatar
2001 CLK55 AMG
MarcusF, do you know what the OEM transmission gasket / filter is?? Or a quality transmission gasket / filter kit? Thanks!
Old Nov 4, 2011 | 12:03 AM
MarcusF's Avatar
2002 CLK430
The OE filter is 1402770095 and the gasket is 1402710080. The retail is $15 each ($11 discounted) and your local dealer may have them in stock. - they fit every 722.6 I know of. V12, 8, 6 supercharged, NA, dual turbos, 4Matic, RWD, everything.
Old Nov 4, 2011 | 10:15 AM
  #32
DRBC43AMG's Avatar
German engineering and thinking (sometimes )
Old Nov 14, 2011 | 03:34 AM
  #33
400HP55's Avatar
2001 CLK55 AMG
UPDATE:
Valve Cover Gasket (Left/Right) - DONE
Brake Fluid Flush - DONE
Cabin Filter - DONE
Air Filters - DONE
Thermostat - Ordered <-- To be installed when I flush collant system
Serp Belt - DONE
Spark Plugs - DONE
Cylinder 6 Wire - DONE
Coil Pack 6 - DONE
Fuel Filter - DONE
Motor/Trans Mounts - Arrived - Needs to be installed
Diff side Seals - Still need to be inspected
Slowly but surely. Its not to expensive if you can figure out how to do the work yourself, and not #$%^ anything up in the process
All I really have left is the fluid flushes. Now I need to find someone in the area to do my Lower Control Arm Bushings for a decent price. Dealership wants $700.....
P.S. I went with W209 mounts afterall
Old Nov 23, 2011 | 12:09 AM
  #34
400HP55's Avatar
2001 CLK55 AMG
Looks like I'm nearing the end of this 100k tune up. Been at it for a few months. 90% has been DIY and I have saved THOUSANDS. I'll update the list once I'm done. Wanted to show you guys a few pics of the mounts I yanked out today. 91k miles and they were LONG overdue to be changed. I slapped the W209 mounts in there. From start to finish it took about 2.5 hours. Wasn't hard at all, but I had help. Tomorrow is my Transmission Service. I only got a few more things and then I should be good to go.... Then the headers and secondary delete... and then ... supercharger...
Cheers!
Attached Thumbnails Tune up list?-photo.jpg   Tune up list?-photo2.jpg   Tune up list?-pic2.jpg
Old Dec 1, 2011 | 07:11 AM
  #35
400HP55's Avatar
2001 CLK55 AMG
Look at what color my transmission fluid is. 90k miles...
Old Dec 4, 2011 | 09:51 AM
  #36
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
My Friends How's everyone? I need some help...I have Clk 55 2004 year,just have a tune on it and k&n filters,looking forward to improve the power & torque but i dont want to spend much money...if any can give me some help or suggestions,i would really appreciate it !
PS: Resonator not deleted, Cat not deleted,Everything concerning the exhaust system is still stock and original
Thanks&Reagrds
Old Dec 4, 2011 | 07:26 PM
  #37
400HP55's Avatar
2001 CLK55 AMG
If I was you I'd reconsider the K&N's. I have seen them cause MAF's to fail.
I did a V.2 intake conversion and gained about 10-15 horses.
I would get high flow secondary cats and a set of headers, keep the resonator! Thats about 20WHP. You'll notice a big difference if you do it all at once.
I would say with a V.2 intake and High flow secondaries + Headers would net you a solid 25WHP without a tune.
