CLK55 2003 : retrofit 55AMG button to C63 AMG paddle shifter on steering wheel
Old Jan 27, 2011 | 05:44 PM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Hi
I own a CLK55 form 2003 with this awesome button on steering wheels to change gear.
So I decide to change for the C63 ones, but it was not plug and play
The ugly buttons
The new paddle shifters
Needded :
- AMG C63 paddles : A1712670046 : about 130€
We starp by the l'airbag
Then the steering wheel
The old buttons :
(DOWN)
(UP)
The connectors are different. On my button blue wires are connected between from each button and the other wire is on a single connector for the 2 button.
On the new paddle there is a connector for each with 2 wire.
The impedence is not the same between bbuttons and paddles.
It is not compatible
Down :
UP:
There is only one way : put the old electronic in the new paddles
Tex5's Avatar
UP
DOWN:
Before :
After :
In the paddle :
Now it is time to work on the steering wheel to make enough space for the new paddles
Tex5's Avatar
Not so bad ? Isn't it ?
In the car :
It is really different. Now I can use the manual mode.
Old Jan 27, 2011 | 05:59 PM
wmasmb430's Avatar
cars
NICE!
Old Jan 27, 2011 | 10:07 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Someone should really consider an exchange program for XX dollars.... swap your stocker for the new style so it's plug-n-play for the customer.
GREAT Pics.
Old Jan 28, 2011 | 04:37 AM
Johnpidge's Avatar
W208 CLK55
Great write up!
Good for 209 owners - wish it could be done for 208 owners
Old Jan 28, 2011 | 04:56 AM
Dome///AMG's Avatar
'16 A45 AMG
I did the same to my old CLK 55 AMG with the steering wheel from the Black Series
But i built a new managment with the old switches behind the airbag
Here u can see the result
Old Jan 28, 2011 | 05:32 AM
betrezra's Avatar
Bravo!
Old Jan 31, 2011 | 11:42 AM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
any soldering involved?
or just dremel action to make everything fit?
Old Jan 31, 2011 | 11:49 AM
Tex5's Avatar
Dremel and drill
2 soldering on the blue wire of the Down paddle to extend it of 10 cm
Old Jan 31, 2011 | 09:52 PM
MBfinatic's Avatar
e36 318i, 2004 sti
This should work on a c55 right?
Old Feb 3, 2011 | 06:28 PM
Tex5's Avatar
A friend of mine had just done it this week on his C55 W203 (after 06/2004) and the electronic was compatible. The only work to do was the adapt the steering wheel emplacements of the paddles
Old Feb 3, 2011 | 07:13 PM
How about going the other way?
Start with a later model wheel with the fat paddles and swap in the button guts from the original wheel??
Avoid lots of time dremeling perhaps?
Old Jun 18, 2011 | 08:36 PM
jazzj's Avatar
clk55 AMG 04
As per the last post, why don't people just buy the C63 wheel from AGE STYLING
http://cgi.ebay.co.uk/Mercedes-SL-R2...#ht_3179wt_989
and as mentioned reuse the wiring from the old CLK wheel. The connectors (for the up and down shift), are obviously different & need to be modified, but I am told the airbag connectors for the old CLK55 AMG 03 W209 should fit up with the C63 wheel. Can anyone please confirm the CLK airbag would just connect in, by reusing the wiring of my old wheel and replugging it into the airbag connectors of the C63 wheel?
If the answer to my question is 'yes', than why aren't more of you doing this mod? Its just a bit of Dremel and soldering work to modify the connectors! Who has bought the AGE SYTLING Wheel?
My point being, if your going to modify the shift buttons, you might as well change to a better wheel? Thoughts please?
Old Jun 19, 2011 | 12:15 PM
Tex5's Avatar
The steering wheel you show is not from a C63 and has no such difference with the stock one. If I had to change it it will be for the Black Series one.
Old Jun 20, 2011 | 05:13 AM
jazzj's Avatar
clk55 AMG 04
My motivation for changing my wheel is my current wheel is worn out, the leather has worn away at the top of the wheel. I could paint it, but quite frankly you would see it if I did so. As a result I am forced to look at alternatives. At the same time, I came across your thread and I thought "wow that's smart".
Im not entirely sure how to read your reply, but if you mean why would you change a wheel if its the same dimensions as the old, then my answer is as per above. Of course I would like a Black Series Wheel, but I cant really justify this.
If your reply gives reinforcement to the fact the AGE styling wheel appears to have the same internals electronics than thats great, infact that's exactly the reasurance I was after
Old Jun 20, 2011 | 05:17 AM
jazzj's Avatar
clk55 AMG 04
I have realised the wheel I have shown is not from a C63? Does anyone know what Merc model it looks like from? Its almost as good as a Black series wheel!!! For $600 US I'm not complaining?!
Old Jun 20, 2011 | 02:52 PM
Tex5's Avatar
I am not having any judgment about changing your steering wheel, just that the one you're looking at is really similar o the stock one (estheticaly) which is not a bad choice at all.
For the electronic compatibility, I can't say, sorry
Old Jun 20, 2011 | 06:57 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Where do you get these paddles from?
Old Jun 20, 2011 | 07:09 PM
Tex5's Avatar
Me ?
It's stock C63 AMG paddles A1712670046
Old Jul 13, 2011 | 11:49 AM
cnchung's Avatar
C32
Great write up
Old Jul 14, 2011 | 10:00 AM
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
Nice Work!
Old Oct 5, 2011 | 11:37 PM
Matutino's Avatar
CLK55
Doing this ASAP :-)
Old Oct 6, 2011 | 03:04 AM
jazzj's Avatar
clk55 AMG 04
Has anyone actually bought this wheel?
http://www.ebay.com.au/itm/220811937...fvi%3D1&_rdc=1
Old Oct 6, 2011 | 06:05 AM
betrezra's Avatar
Make sure your stock clk55 air bag will work with that BS clk63 wheel. Looks nice.
