Camshaft questions
On my 55k I have found although they make incredible power, they seem to have a lopey idle and seem a bit too aggresive for my taste...to each his own I guess...
but my car made tons of power and tq - 509.2 hp and 589.6 ft-lb of tq at the rear wheels
curious to see what some of you guys think...
Cheers _PTEngineering
http://www.youtube.com/watch?v=shgw1AANOF0
http://www.youtube.com/watch?v=24XIqtajQbM
Hope this helps your decision
Don't the NA 55 motors need different valve springs? If so, what's the part numbers if I do decide to buy a set of these?
I used the stock valve springs ,There good to 6800 rpm, But I installed Titanium Retainers , because I new I might see 7000 rpm and did not want to chance Valve float if I missque on a down shift.
Nice sound and smooth acceleration It does sound a touch lopey at the beginning but smooths out nice. I imagine with a quieter exhaust you probably would not notice too much either.
The Mustang & Chevy crowd seem to know the difference. Quiet or loud.
I've had these cams in the engine for over 6000 miles of Driving , mostly short trips & Street & Drag Strip use. The car miles are just at 19,300.
The hardest part was finding all the Vacuum leaks. I ended up using a Clamp on hose connections. This helps with getting a smoother Idle & good drivability. It Makes like a lot easier for the tuner to tweek in the Fuel / Air , ratios
Thus far I have given one counter offer to the initial guy who responded and whom I told would have first dibs. I am still waiting on his reply.
thanks all, please note that whomever the buyer turns out to be you have Pat's (PTE) help and support should you need it.
In Havoc's issue was one of the custom pistons , that where in his engine , did not have enough relief fly cut in the dish area , too have the proper clearence for the 1mm over sized intake & Exhaust valves , built for VRP by Ferrera . Plus I believe Havoc's engine had the deck surfaced on the block & Heads. I have over 29 sets of these cams out there . and no known fitment issue on stock m-113 engines. Sunir's cams were just too much for his driving taste . That's is why I posted my Youtube stuff. This cams are a good deal for somebody who wants more top end HP. With a willingness to give up a little of that velvet smooth idle quality.
Hope this helps . this debate could go on for a long time and still not be the right stuff for some peoples taste, Hence the youtude vidoes
Cheers _PTengineering
How are the AFRs affected? engine longevity? Can the car actually stall or cut out at times? Will it really cause your coffee to spill if uncovered?
Thanks Pat for your thorough explanation. I am almost going to pull the trigger. My tuner told me the gains he has seen about 8rwhp although still hard to isolate based on the cars he tuned with with these cams.
I pretty much know where most of the VRP / cams ended up & what cars they are on. My Quess your tuner has not worked on a Car with the VRP / PTE cams.
You should get your Hardware issues fixed first. Get your ongoing 4 year Car trama's out of the way . DC has taken on a Project that has had never ending problems. I'm sure they will help you get straightened out .and running Correctly! Please wait before installing this more aggressive grind Cam, They will compound your current issues.
Best of luck with your future endeavours. _PTEngineering
Do you have any dynograph information on these cams compared to stock on your CLK55? I'm interested in NA gains but also wondering how they would/could work with the Kleemann supercharger?
If you put new mercedes Dual springs on . You are set to go!!
Kevwood:
I do not have any Dyno Charts for the VRP cams in a N/A motor. But I did sell ,C-55 asleep, a set of SLR cams & he saw & showed the before & after dyno . On The C-32 ? C-55 forums, They got him 11 RWHP. VRP cams Have more lift & open the intake valves sooner than the SLR cams. I can Only guess may 16 - 18 RWHP over stock cams with the VRP cams.
Kevwood:
please email me as sunirghosal@hotmail.com for purchase inquiries.
have a great weekend everyone!
Kevwood:
