Issues installing after market radio in CLK500
Now Here is my issue. I just purchased a 2004 CLK500 and Im trying to get an after market pioneer Head unit in it. Today I went to 3 car audio shops and got 3 different answers..... the first: Told me there was no parts made to install a double din (which I know isnt true). the second: said it was impossible to change out a MB head unit because of the fiber optics, and the third said I would have to rewire my whole audio system and to do that alone would be 1500 bucks not including the actual installation and amp work.... HELP... I know this isnt that hard and if it is id rather hear it from a fellow owner... is there any hope for me on this .... thanks in advance
Right now I am trying to find a good spot to mount the amp.
Now if you want to use the factory amp, which I don't recommend, then it would just require an adapter to allow you to connect your headunit to the amp with rca's. The speakers would sound much better with an aftermarket amp. They all run at 2ohm, so you would just need to find an amp that is 2ohm stable. Running the power cable is fairly simple as well, you just run down the passenger side and there is a pass through in the front passenger side foot well. I think there's a grommet you can remove that puts you right at the battery.
This was a first attempt for sound, Believe it or not the schoshe crossover works great. I can blaze Acoustic clapton and homp with the boyz. I fabbed a birch wood stand for these but want more updated amps though this was a test.
For fiber interface options besides Marcus Link I would read thoroughly any post by skylaw in this forum and others. (telematics)
Cheers, Gator
I am all assembly.
I used a factory amp (e-bay) to interface with the OEM command as it increases volume with the top down and has Voice control. etc...,
The Schoche has adjustable gain for tweaking input to the other amps which were lying about in the shop. If you wish to pursue this route try amps with adjustable input sensitivity as well. My next venture is fiber interface for droid via D2B dension Gateway module.
All the best, Gator Dont click the link,
