Renntech Airbox/AFE air filter install
Old Feb 11, 2012 | 12:26 AM
03renntechamg's Avatar
2005 Mercedes E55 AMG
Like the title says, I just installed the renntech carbon fiber airbox on my 03 clk55, I also added the afe dry flow filters. This has been covered a number of times so im going to be brief.
My overall reveiw for this product is pretty good considering the price I paid for the airbox, I found it locally on craigslist for a great deal. I would not reccomend paying full price for this item, as I feel there is such a better design that can be created (ie: needswing).
Anyways as far as performance goes I definatly think I gained a couple ponies in the top end as well as a little tq down low. As well as a little under the hood grunt. I do realize I really need a tune to reap total benefits but the gain was nothing like I was expecting.
I did gain about 1mpg on my daily commute (about 30 miles) which is a plus.
The next mod will be a secondary cat delete and exhaust, hopefully its a more noticable mod.
Old Feb 11, 2012 | 12:39 AM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
I agree with everything you said. I can't say I honestly "feel" any difference but several same day, same dyno, same operator back to back dynos indicate there's a gain. I think a matching tune would be beneficial.
Old Feb 11, 2012 | 08:07 AM
betrezra's Avatar
C63 507 AMG DA Car #19
An interesting note about the renntech intake:
I installed this on our ML500 and watched the LTFT's go up as a result to 1.06/1.06.... so it does add air and fuel over the base map which is good.
The only way I could tell it added power was if you took it off and put the stocker back in place it was noticably down on power.
If you mpg went up..... perhaps it's lean... I would check your fuel trims with a OBDII reader or star just to be on the safe side.
I"m sure your fine, but pc of mind is good.
Old Feb 11, 2012 | 08:31 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If the airbox is flowing more air then the AFR's are going to be leaner thus making more HP and your milage will also get better since HP is a byproduct of efficiency. Our cars are pig rich from the factory, I doubt it'll be lean (over 13:1) but I do agree with Jeff to check the trim levels for piece of mind.
Old Feb 11, 2012 | 04:08 PM
Thanks for the reply's fellas!!! Im sure my car is running fine, the mpg increase was barely noticable and honestly could just be because I was trying to conserve fuel.
On a side note, I just noticed my clk has the dreaded valeo radiator still in it at 90k miles!!!! This worries me big time!!!! Should I be worried, if im not experienceing any symtoms?
Old Feb 12, 2012 | 12:09 AM
Kevwood's Avatar
I'd change it out, why take chances right?
Old Feb 12, 2012 | 12:10 AM
MarcusF's Avatar
2002 CLK430
Pelican Parts has them for $330. That and a couple of hours of should take care of any concerns.
Old Feb 13, 2012 | 12:23 PM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
I did notice a difference too. The real test will be at the 1320 this spring. You forgot to mention the awesome looks. haha.
Old Feb 13, 2012 | 12:52 PM
elijah's Avatar
Euro Cars Only
If I find a slighty used one ill jump on it cuz buying it new is a ripoff!
Old Feb 13, 2012 | 11:15 PM
Exactly.
