410HP N/A W208 Possible?
Subscribe
Jul 12, 2012 | 02:53 PM
Quote: By the way: do you have an idea if possible to put the E55k/SL55k/CL55k/S55K or SLK55 oil cooler with filter housing to the W202 C43 or C55,, im thinking
to do that cause they have an External cooler......!!
ZAYED,,
I sure don't, sorry.
Quote: ANy experience with the SLR cams?
No experience, but I know they're not as aggressive as PTE cams. SLR cams are similar to Kleeman cams and are mild. From what I remember the SLR cams have less lift but more overlap than the stock 55K cams. I have the specs on them if needed.
Reply 0
Jul 14, 2012 | 04:30 PM
I have a W209 CLK 55 and if I add: headers, x-pipe,tune would it hit 400 hp???
Or would I have to add the renntec air box?
Thank you all for the info.
Reply 0
Jul 16, 2012 | 11:43 AM
Quote: I have a W209 CLK 55 and if I add: headers, x-pipe,tune would it hit 400 hp???
I have your suggested mods, minus tune and x-pipe.
If you go with MBH headers, a good tune, and find a shop that can do an x-pipe, heard it is not the easiest on our cars.
I think 400fwhp should be possible.
Reply 0
Jul 18, 2012 | 10:06 PM
Thank you all for the info an answering my question.
Has anyone tried out a set of cams???
Reply 0
Jul 19, 2012 | 01:33 PM
Havoc did with a set of PTE cams, and he yielded 5whp and 10tq on Cam only swap. No retune.
Reply 0
Jul 19, 2012 | 11:16 PM
A gain is a gain but dang those are low numbers. If you put a cam in an LS3 it hit just about 500 hp.
I was in visioning adding: tune, exhaust, headers, renntec air box, and cams to = 415 rwph. What do you all think?
Since its not going to hit my goal i can take that mod money and it to my savings for a clk 63 black.
Reply 0
Jul 20, 2012 | 12:50 AM
  #32
I'll let you know in the next few months... already have Kleemann headers and dual exhaust with no cats or resonator...just bought PTE cams and still have a new AMS crank pulley to install, and will be purchasing an Evosport UDP set. Working on a high-flow intake, then a custom dyno tune by Eurocharged
Reply 0
Jul 20, 2012 | 05:24 AM
  #33
Brizz - there just is not as much potential left on the table of this motor like and LSX or fomoco motor. IMHO.
Dre- looking forward to seeing a high HP/TQ n/a combo.
Reply 0
Explore
Jul 20, 2012 | 10:29 AM
  #34
Quote: A gain is a gain but dang those are low numbers. If you put a cam in an LS3 it hit just about 500 hp.
Only LSxs take to cam swaps like that lol.
Bone stock these things put down 290ish wheel hp. I believe the highest N/A dyno for a M113 with the 5speed was in the 380's by hooleyboy. Dre put down 377whp I believe.
I do not think that above 400whp is possible N/A. More important than wheel hp though is 1/4 mile times. Take it to the track for some 1320 action. If you run 12's you have done good.
Btw: If you don't want to go crazy on the mod budget, just get a tune, kleemann headers, and some AFE pro-dry S filters. May set you back only 1500, but will transform the car.
Reply 0
Jul 20, 2012 | 12:55 PM
  #35
Quote: I do not think that above 400whp is possible N/A. More important than wheel hp though is 1/4 mile times. Take it to the track for some 1320 action. If you run 12's you have done good.
^^..+1..^^
ZAYED,,
Reply 0
Jul 20, 2012 | 02:11 PM
  #36
I wouldn't say its not possible... Just not cheap or bolt on
Reply 0
Jul 20, 2012 | 03:43 PM
  #37
Good luck
Reply 0
Jul 21, 2012 | 10:12 AM
  #38
But I thought Kleeman does not sell headers for the W208 anymore?
And the cheapest tune I found was $900.
What you guys think?
Do you guys think that fitting the 2005 CLK55 intake onto my W208 helped?
Reply 0
Jul 21, 2012 | 04:13 PM
  #39
I should just buy a 6.3L out of a crashed c63 and swap it into my clk.
Reply 0
Jul 21, 2012 | 05:14 PM
  #40
Or get a used clk63 (non-BS)...... they are out there..... alot of potential with bolt-ons tune.
Reply 0
Jul 21, 2012 | 07:39 PM
  #41
Hooley boys car is not N/A its S/C and I doubt the other one you mentioned is N/A either.
Reply 0
Jul 24, 2012 | 11:37 AM
  #42
Quote: Hooley boys car is not N/A its S/C and I doubt the other one you mentioned is N/A either.
When hooley boy's car was N/A, it made those numbers. It was before his supercharger and may have been his 100 octane tune. Cannot remember.
Dre put down 377whp, and yes he is N/A.
The SLK55 was also N/A.
Kind of difficult to confuse a supercharged car for an N/A one lol.
I will not search for all the threads...but here is Dre's 377whp N/A thread. Please note the mention of the other two N/A dynos, one being hooley boy, the other being the SLK55.
https://mbworld.org/forums/c32-amg-c...o-results.html
Reply 0
Aug 16, 2012 | 01:15 AM
  #43
Hi Guys,
The W208/W209 and W210 boards seem to be the most active in modding their M113 N/A motors so I've been reading up quite a bit on many of your threads.
This thread in particular caught my attention because I've been interested in some incremental mod numbers for the M113 N/A motor. On the W463 boards there aren't many people modifying the pre supercharged M113's.
Does anyone know the whp gain for Kleemann shorty headers plus cats plus ecu tune on an M113 N/A?
I was able to find a used set from this board and will be installing them on my 2003 G55 within the next couple of weeks.
I also bit the bullet and ordered the Kleemann Supercharger system for the M113 5.5. It's somewhere over the Pacific Ocean now and I should have it by next week. Needless to say I'm very excited for install and the results.
I'll be documenting the install on a separate thread. Before I go on with the install, does anyone who has done a similar install have any input about things to look out for and to pay close attention to? Since I'm in the Philippines, there are no authorized Kleemann installers here. I'll be doing the install with my indy mechanic.
Reply 0
Aug 16, 2012 | 03:36 AM
  #44
BonitaBeast, do you know of anyone else who has headers for sell?
What other headers would fit our cars?
Reply 0
Aug 16, 2012 | 11:44 AM
  #45
Quote: BonitaBeast, do you know of anyone else who has headers for sell?
Sorry no I don't know of any other set for sale. As a matter of fact I found mine by chance. I was looking for OEM brakes and it just so happened the seller had a complete kleemann exhaust set with cats, downpipes, etc. along with a whole bunch of other stuff.
As for who else makes headers for your car, I believe OBX has headers for W208/W209.
There's also a set on ebay for sale now. I don't know how good they are though.
http://www.ebay.com/itm/Mercedes-Ben...item564bd89817
Reply 0
Aug 16, 2012 | 05:03 PM
  #46
Quote: Or get a used clk63 (non-BS)...... they are out there..... alot of potential with bolt-ons tune.
Too bad the coupe never came here Verts are not my thing.
Reply 0
Aug 16, 2012 | 06:27 PM
  #47
Werd Nach - coupe c63 (non-BS) would be nice.
Reply 0
Aug 20, 2012 | 06:17 PM
  #48
Quote: When hooley boy's car was N/A, it made those numbers. It was before his supercharger and may have been his 100 octane tune. Cannot remember.
With just headers and exhaust 377whp,I doubt it and they better check that dyno! Sounds like S.A.E hp and not corrected.That dyno is reading pretty high there my friend. Look at PTE's car which had the same mods ran 12's and did 342whp and 361ftlbs of tq max just before he put on the Kleeman s/c.
His mods are listed in this thread as well as his dyno.
https://mbworld.org/forums/clk55-amg...ms-review.html
My car with present mods put out 337rwhp(Kleemann cams at the time I think!) took them out and sold them back then as well. Still gonna one day get the PTE cams or just drop in the S/C.
Reply 0
Aug 20, 2012 | 06:51 PM
  #49
342 rwhp is a very good number when you consider the crank HP is 369.
Reply 0
Aug 20, 2012 | 07:08 PM
  #50
Quote: 342 rwhp is a very good number when you consider the crank HP is 369.
Yes Patrick really did his car up put just about every bolt on you could think of prior to the S/C.
Hooley boys car N/A is not putting out 389rwhp corrected. NoWAY!!!! Uncorrected perhaps!
The 1/4 mile # your car posted tells me alot as well. 13.5 @105 mph if this was prior to your exh build I'll assume.
Headers SW and exhaust wake these cars up but not 70rwhp!
Reply 0
