2002 CLK 55 Transmission Question
Old Sep 27, 2013 | 09:42 AM
Veritas17's Avatar
2002 CLK 55 Cabriolet, 2008 G37 Sport, 1982 Corvette
Cool 2002 CLK 55 Transmission Question
I just purchased a 2002 CLK 55 convertible a few months ago. Car is in mint condition. I ran it pretty hard one day and nailed the gas while getting on the interstate, it took off like a rocket than all of a sudden the transmission disengaged and the engine spun like it was in neutral. I pulled over, put it back in drive and off I went with no problem. I did notice i was in the W mode so I am wondering if this was a fail safe on the car since I had the traction control on to prevent me from going to fast. I put it back in the S mode and nailed the gas again with no problems.
Appreciate any input
Old Sep 27, 2013 | 11:13 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it went into limp mode for some reason when you ran it hard. There will be some soft codes stored in the TCU. Check the fluid level.
Old Sep 27, 2013 | 11:40 AM
Veritas17's Avatar
Will do... I know the car does no have a dip stick for the Tranny.. what do use to check the fluid?
Old Sep 27, 2013 | 12:04 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Get a copy of DAS STAR...... you can do some diag yourself..... or go to indy shop.
Old Sep 27, 2013 | 12:10 PM
Veritas17's Avatar
is DAS STAR a diagnostic program? What do you mean by get a copy
Old Sep 27, 2013 | 12:16 PM
shardul's Avatar
copy of the fault codes displayed via the Star diagnostic program.
Old Sep 27, 2013 | 12:42 PM
Veritas17's Avatar
I have a actron cp 9575 scanner for my other cars- see no reason why it won't work on the clk
Old Sep 27, 2013 | 03:37 PM
betrezra's Avatar
You can scan some basic eng codes w/OBD scanner..... but the best diag tool will be DAS STAR...... can find a good knock off for $500.... g/l>
Old Sep 27, 2013 | 07:00 PM
Veritas17's Avatar
put the scan on pulled a po700 code - transmission systems malfunction... I am having the fluid flushed what could cause this code to POP? Tranny went into limp mode yesterday after stomping on the gas
Old Oct 1, 2013 | 01:12 PM
Veritas17's Avatar
Wanted to follow and provide an update. I brought my car to a reputable Transmission shop here in Charlotte NC. I had them do a flush and clear the code after inspection. The cost was $199.00! Every MB shop wanted $500.00! He flushed it all new filter and 9 plus quarts of fluid. Car runs great now, even noticed smoother shifting all around. The fluid level was fine and the tech said it was not that dirty so who knows why it went into limp mode. He said it could have been the throttle body sticking or the computer had a signal error etc. I have run it a little hard but so far no limp mode. Just an FYI!
